查看: 15598|回复: 5
stm32L152工程模板及操作内部自带的EEPROM示例(测试开发板为stm32L discovry)
42
128
128
2011-8-16
发表于 2012-6-25 18:01:28 | 显示全部楼层 |阅读模式
 *    Used with ICCARM and AARM.
 *    (c) Copyright IAR Systems 2011
 *    File name   : main.c
 *    Description : Define main module
 *    author: yang yongzhen
 *    qq:534117529
#include <intrinsics.h>
#include "stm32l1xx.h"
//总共4096Bytes,即4K
#define EEPROM_START_ADDR   0x08080000
#define EEPROM_END_ADDR     0x08080FFF
void LEDInit()
  GPIO_InitTypeDef  GPIO_InitStructure;
  /* Enable the GPIO_LED Clock */
  RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOB, ENABLE);
  /* Configure the GPIO_LED pin */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz;
 // STM32_LEDOff(Led);
  GPIO_SetBits(GPIOB,GPIO_Pin_7);
void Delay(__IO uint32_t nCount)
  while(nCount--)
void write_eeprom(uint32_t address,uint8_t data)
    if(IS_FLASH_DATA_ADDRESS(address))
        FLASH_UnlockProgram();
        while(FLASH_GetStatus()!=FLASH_COMPLETE);
        FLASH_WriteDataByte(address, data);
        FLASH_LockProgram();
uint8_t read_eeprom(uint32_t address)
    uint8_t tmp=0;
        while(FLASH_GetStatus()==FLASH_BUSY);
        tmp=*(__IO uint8_t*)address;
    return tmp;
 * Function Name: main
 * Parameters: none
 * Return: none
 * Description: main
void main(void)
//NVIC_InitTypeDef NVIC_InitStructure;
//TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStruct;
  __disable_interrupt();
  /* Setup STM32 system (clock, PLL and Flash configuration) */
  SystemInit();
  // NVIC init
#ifndef  EMB_FLASH
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);
  // LEDs Init
  LEDInit();
  Delay(0xFFFF);
  GPIO_ResetBits(GPIOB,GPIO_Pin_7);
  for(int i=0;i<16;i++)
     write_eeprom(EEPROM_START_ADDR+i,i);
  __enable_interrupt();
  char temp,temp1;
  temp=read_eeprom(EEPROM_START_ADDR);
  temp1=read_eeprom(EEPROM_START_ADDR+15);
  if((temp==0)&&(temp1==15))
      while(1);
     Delay(0x0FFFF);
     Delay(0x0FFFF);
//说明:看到开发板上LED3,黄灯闪烁,说明写入和读取不成功,否则黄灯一直亮,说明确实读写成功了。
stm32L152模板及操作内部EEprom.rar
119 Bytes, 下载次数: 1843
发表于 2012-6-25 18:20:48 | 显示全部楼层
谢谢分享.
2013-9-11
发表于 2014-1-1 20:35:38 | 显示全部楼层
是空的没文件
专业研发生产GPRS、有线、无线测温仪
302
774
774
2012-6-19
19 小时
发表于 2014-5-14 09:49:06 | 显示全部楼层
69
69
2013-8-26
发表于 2014-7-30 10:04:31 | 显示全部楼层
我上传一个IAR里面的MCD Application Team出品的代码和头文件吧。一个.c和2个.h,解压后放在main.c那个目录里面,projec里面include那个c文件即可使用该c文件里面的各种EEPROM函数。
STM32L1XX EEPROM.rar
53.27 KB, 下载次数: 1036
69
69
2013-8-26
发表于 2014-8-2 16:33:07 | 显示全部楼层
DATA_EEPROM_Unlock();//先解锁EEPROM,才能写eeprom
*(__IO uint32_t *)0x08080000=0x1111// 假设要存入eeprom的值为0x1111
a=*(uint32_t*)0x08080000;//将eeprom地址为0x08080000的内容,赋给a。
GMT+8, 2026-11-5 08:38
