查看: 4460|回复: 2
STM8S005读取5883的时候,用ST-LINK在线仿真可以读取数据,但是下载到片上运行时就无法运行
29
29
2015-12-9
发表于 2015-12-9 15:56:17 | 显示全部楼层 |阅读模式
STM8S005读取HMC5883的时候,用ST-LINK在线仿真可以读取数据,但是下载到片上运行时就无法运行。用逻辑分析仪观察波形是一模一样的。可能时间间隙上有区别。是器件本身的问题呢还是什么的。。。搞了两三天,有点晕。
附上IIC底层代码
* Function Name : I2C_GPIO_Config
* Description   : Configration Simulation IIC GPIO
* Input         : None
* Output         : None
* Return         : None
void I2C_INIT(void)
/* I2C_Init(100000, 0xAAA, I2C_DUTYCYCLE_2, I2C_ACK_CURR, I2C_ADDMODE_7BIT, 16);
I2C_Cmd(ENABLE); */
GPIO_Init(GPIO_IIC1,PIN_IIC1_SDA,GPIO_MODE_OUT_OD_HIZ_SLOW);
GPIO_Init(GPIO_IIC1,PIN_IIC1_SCL,GPIO_MODE_OUT_OD_HIZ_SLOW);
SDA_H;
SCL_H;
* Function Name : I2C_delay
* Description   : Simulation IIC Timing series delay
* Input         : None
* Output         : None
* Return         : None
void I2C_delay(void)
nop();
nop();
nop();
nop();
nop();
void delay5ms(void)
   unsigned int i;
   i=5000;
   while(i--) ;
* Function Name : I2C_Start
* Description   : Master Start Simulation IIC Communication
* Input         : None
* Output         : None
* Return         : Wheather Start
uint16_t I2C_Start(void)
SDA_H;
SCL_H;
I2C_delay();
if(!SDA_read)return FALSE; //SDA线为低电平则总线忙,退出
SDA_L;
I2C_delay();
if(SDA_read) return FALSE; //SDA线为高电平则总线出错,退出
SDA_L;
I2C_delay();
return TRUE;
* Function Name : I2C_Stop
* Description   : Master Stop Simulation IIC Communication
* Input         : None
* Output         : None
* Return         : None
void I2C_Stop(void)
SCL_L;
I2C_delay();
SDA_L;
I2C_delay();
SCL_H;
I2C_delay();
SDA_H;
I2C_delay();
* Function Name : I2C_Ack
* Description   : Master Send Acknowledge Single
* Input         : None
* Output         : None
* Return         : None
void I2C_Ack(void)
SCL_L;
I2C_delay();
SDA_L;
I2C_delay();
SCL_H;
I2C_delay();
SCL_L;
I2C_delay();
* Function Name : I2C_NoAck
* Description   : Master Send No Acknowledge Single
* Input         : None
* Output         : None
* Return         : None
void I2C_NoAck(void)
SCL_L;
I2C_delay();
SDA_H;
I2C_delay();
SCL_H;
I2C_delay();
SCL_L;
I2C_delay();
* Function Name : I2C_WaitAck
* Description   : Master Reserive Slave Acknowledge Single
* Input         : None
* Output         : None
* Return         : Wheather Reserive Slave Acknowledge Single
uint16_t I2C_WaitAck(void) //返回为:=1有ACK,=0无ACK
SCL_L;
I2C_delay();
SDA_H;
I2C_delay();
SCL_H;
I2C_delay();
if(SDA_read)
      SCL_L;
 I2C_delay();
      return FALSE;
SCL_L;
I2C_delay();
return TRUE;
* Function Name : I2C_SendByte
* Description   : Master Send a Byte to Slave
* Input         : Will Send Date
* Output         : None
* Return         : None
void I2C_SendByte(unsigned char SendByte) //数据从高位到低位//
    u8 i=8;
    while(i--)
        SCL_L;
        I2C_delay();
      if(SendByte&0x80)
        SDA_H;
        SDA_L;
        SendByte<<=1;
        I2C_delay();
SCL_H;
        I2C_delay();
    SCL_L;
* Function Name : I2C_RadeByte
* Description   : Master Reserive a Byte From Slave
* Input         : None
* Output         : None
* Return         : Date From Slave
unsigned char I2C_RadeByte(void)  //数据从高位到低位//
    u8 i=8;
    u8 ReceiveByte=0;
    SDA_H;
    while(i--)
      ReceiveByte<<=1;
      SCL_L;
      I2C_delay();
 SCL_H;
      I2C_delay();
      if(SDA_read)
        ReceiveByte|=0x01;
    SCL_L;
    return ReceiveByte;
29
29
2015-12-9
 楼主| 发表于 2015-12-9 20:23:58 | 显示全部楼层
坐等神人回复。。。。
29
29
2015-12-9
 楼主| 发表于 2015-12-10 11:58:02 | 显示全部楼层
找到问题,初始化5883的时候,本来只对0x02的寄存器初始化,没有对0x00跟0x01初始化,加上初始化后即可。
GMT+8, 2026-11-12 13:01
