查看: 14350|回复: 23
求助:STM32F407 用TIM4通过DMA修改GPIOE的值,修改不了
56
56
2016-3-1
11 小时
发表于 2016-3-1 09:35:40 | 显示全部楼层 |阅读模式
2金钱
求教大家,我用TIM4 定时器通过DMA来修改GPIOE的值,却修改不了;调试中发现DMA也启动了,因通过寄存器发现为修改TIM4 CCR1的值是能修改了,
但GPIOE->ODR或GPIOE->BSRR却没有变化,请问是什么原因?用的STM32F407,下面是我的代码:
#define TIM4_CCR1_ADDRESS  ((uint32)0x40000834) /* TIM4 CCR1 address */
#define GPIOE_ODR_ADDRESS  ((uint32)0x40021014) /*  address */
uint16 a_SRC_Buffer[4] = {0x0023, 0x0045, 0x00d3, 0x004a};
函 数 名: TIM_GPIO_Init     TIM4
功    能:定时器输出通道GPIO初始化
参    数: 无
返    回: 无
void TIM_GPIO_Init(void)
  DMA_InitTypeDef          DMA_InitStructure;
  /* TIM4 clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1PERIPH_TIM4, ENABLE);
  /* GPIOA clock enable */
  RCC_AHB1PeriphClockCmd(RCC_AHB1PERIPH_GPIOD | RCC_AHB1PERIPH_GPIOE, ENABLE);
  /* DMA1 clock enable */
  RCC_AHB1PeriphClockCmd(RCC_AHB1PERIPH_DMA1, ENABLE);
  /* GPIOA Configuration: PD12(TIM4 CH1) as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_PIN_12;
  GPIO_InitStructure.e_GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.e_GPIO_Speed = GPIO_SPEED_100MHZ;
  GPIO_InitStructure.e_GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.e_GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  /* Connect TIM pins to AF1 */
  GPIO_PinAFConfig(GPIOD, GPIO_PIN_SOURCE12, GPIO_AF_TIM4);
  /* DeInitialize the DMA1 Stream6 */
  DMA_DeInit(DMA1_Stream6);
  DMA_InitStructure.DMA_Channel = DMA_Channel_2;
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32)(&(GPIOE->ODR)); //&(GPIOE->BSRRL) 值没有变化
  //DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32)(TIM4_CCR1_ADDRESS); /* 可以正常修改它的值 */
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32)a_SRC_Buffer;
  DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
  DMA_InitStructure.DMA_BufferSize = 4;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//DMA_Mode_Normal;
  DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Enable;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  DMA_Init(DMA1_Stream6, &DMA_InitStructure);
函 数 名: TIM_DMA_Output_Init
功    能:定时器DMA方式输出通道初始化
参    数: 无
返    回: 无
void TIM_DMA_Output_Init(void)
  TIM_OCInitTypeDef  TIM_OCInitStructure;
  TIM_TimeBaseStructure.TIM_Period = 1000;
  TIM_TimeBaseStructure.TIM_Prescaler = 42 - 1;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_COUNTERMODE_UP;
  TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
  /* TIM Configuration in PWM Mode */
  TIM_OCInitStructure.TIM_OCMode =  TIM_OCMode_Toggle;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = a_SRC_Buffer[0];//0xFFF;
  TIM_OC1Init(TIM4, &TIM_OCInitStructure);
  /* TIM4 DMA Update enable */
  TIM_DMACmd(TIM4, TIM_DMA_Update, ENABLE);
        TIM_SelectOutputTrigger(TIM4, TIM_TRGOSource_Update);
  /* TIM4 enable */
  TIM_Cmd(TIM4, ENABLE);
  /* TIM4 PWM Outputs Enable */
//  TIM_CtrlPWMOutputs(TIM4, ENABLE);
  /* Enable DMA2 Stream5  */
  DMA_Cmd(DMA1_Stream6, ENABLE);
//  /* Wait until DMA1 Stream6 end of Transfer */
//  while (!DMA_GetFlagStatus(DMA1_Stream6, DMA_FLAG_TCIF6))
void TLC7524_GPIO_Init(void)
  GPIO_InitTypeDef  s_GPIO_InitStructure;
  /* Enable GPIOs clock */
  /* GPIOI configuration */
  s_GPIO_InitStructure.GPIO_Pin = GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_4 | GPIO_PIN_5 | GPIO_PIN_6 | GPIO_PIN_7;
  s_GPIO_InitStructure.e_GPIO_Mode = GPIO_Mode_OUT;
  s_GPIO_InitStructure.e_GPIO_OType = GPIO_OType_PP;
  s_GPIO_InitStructure.e_GPIO_Speed = GPIO_SPEED_100MHZ;
  s_GPIO_InitStructure.e_GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_Init(GPIOE, &s_GPIO_InitStructure);
发表于 2016-3-2 23:27:53 | 显示全部楼层
56
56
2016-3-1
11 小时
 楼主| 发表于 2016-3-7 13:14:28 | 显示全部楼层
自己顶一个
60
409
2814
2814
2012-10-17
653 小时
发表于 2016-3-15 09:11:04 | 显示全部楼层
是不是像原子教學裡面說的 DMA1不能訪問memory (聽說GPIO算memory)
我亂猜的~我現在用TIM2_UP要寫GPIOB->ODR
用DMA1_Stream1也不能用....
228
1732
1732
2016-3-8
679 小时
发表于 2016-3-15 09:25:07 | 显示全部楼层
貌似DMA不支持P2P,即外设到外设的传输。不知道是不是这个问题。
56
56
2016-3-1
11 小时
 楼主| 发表于 2016-3-16 16:51:20 | 显示全部楼层
我亂猜的~我現在用TIM2_UP要寫GPIOB ...
GPIO算外设吧,也有人说DMA1通过TIM驱动不能访问GPIO,但DMA2可以,你试过DMA2没?
60
409
2814
2814
2012-10-17
653 小时
发表于 2016-3-17 13:39:15 | 显示全部楼层
用TIM1_UP可以修改GPIO->ODR
GPIO->ODR  算外設位址沒錯
38
38
2013-5-14
发表于 2016-6-8 07:39:11 | 显示全部楼层
我也遇到求助:STM32F407 用TIM4通过DMA修改GPIOE的值,修改不了这样类似的问题,请问解决了没?
38
38
2013-5-14
发表于 2016-6-8 08:49:12 | 显示全部楼层
GPIO->ODR  算外設位址沒錯
time up有程序吗?粘出来,谢谢
60
409
2814
2814
2012-10-17
653 小时
发表于 2016-6-8 09:06:04 | 显示全部楼层
有何不可 发表于 2016-6-8 08:49
time up有程序吗?粘出来,谢谢
只有dma2的外設地址可以設定GPIOx->ODR
void TIM8_ADCLK_Init(u32 arr, u32 psc)
        RCC->APB2ENR |=1<<1;    //enable TIM8 clk
        RCC->AHB1ENR |=1<<2;    //enable PORTC clk
        GPIO_Set(GPIOC,PIN8,GPIO_MODE_AF,GPIO_OTYPE_PP,GPIO_SPEED_2M,GPIO_PUPD_PU);
        GPIO_AF_Set(GPIOC,8,3); //PC8 AF3 TIM8_CH3
        TIM8->CR2=2<<4; //UI TRGO
        TIM8->ARR = arr;
        TIM8->PSC = psc;
        TIM8->CCR3= arr*0.14;  //D=0.5 DMA_CC3 output ADCCLK
        TIM8->CCR4= arr*0.25;  //D=0.5 DMA_CC4 Trgo DMA2_Stream4
        TIM8->CCMR2 |= 6<<4;  //PWM mode  CNT<CCR3 OC3=effective Level
        TIM8->CCER  |= 1<<8;  //enable OC3 output
        TIM8->CCER  |= 0<<9;  //OC3 polarity High Level effective
        TIM8->DIER |= 1<<11;  //enable CC3 DMA request
        TIM8->DIER |= 1<<12;  //ebalbe CC4 DMA request
        TIM8->BDTR  |= 1<<15; //enable main output
        DMA2_TIM8_Ch3();
void DMA2_TIM8_Ch3(void)
        RCC->AHB1ENR |= 1<<22; //enable DMA2 clk
        DMA2_Stream4->PAR = (u32)&GPIOE->ODR;        //Peripheral address
        DMA2_Stream4->M0AR =(u32)RACA;                        //Memory address
        DMA2_Stream4->NDTR =120*160;                        //number of data
        DMA2_Stream4->CR |= 1<<6;                                //Memory to Peripheral
        DMA2_Stream4->CR |= 1<<8;                                //enable Circular mode
        DMA2_Stream4->CR |= 0<<9;                                //DISABLE Peripheral increment mode
        DMA2_Stream4->CR |= 1<<10;                                //ENABLE Memory increment mode
        DMA2_Stream4->CR |= 1<<11;                                //Peripheral data size 16bit
        DMA2_Stream4->CR |= 1<<13;                                //Memory data size 16bit
        DMA2_Stream4->CR |= 3<<16;                                //Priority level 3
        DMA2_Stream4->CR |= 0<<21;                                //Peripheral burst transfer configuration
        DMA2_Stream4->CR |= 0<<23;                                //Memory burst transfer configuration
        DMA2_Stream4->CR |= 7<<25;                                //selection Channel7
        DMA2_Stream4->CR |=1<<0;
//read AD9200 Data
void DMA2_TIM8_Ch4(void)
    DMA2_Stream7->PAR = (u32)&GPIOG->IDR;    //Peripheral address
    DMA2_Stream7->M0AR =(u32)raw_data;    //Memory address
    DMA2_Stream7->NDTR =120*160;            //number of data
    DMA2_Stream7->CR |= 0<<6;                //Peripheral to Memory
    DMA2_Stream7->CR |= 1<<8;                //ENABLE Circular mode
    DMA2_Stream7->CR |= 0<<9;                //DISABLE Peripheral increment mode
    DMA2_Stream7->CR |= 1<<10;                //ENABLE Memory increment mode
    DMA2_Stream7->CR |= 1<<11;                //Peripheral data size 16bit
    DMA2_Stream7->CR |= 1<<13;                //Memory data size 8bit
    DMA2_Stream7->CR |= 2<<16;                //Priority level 2
    DMA2_Stream7->CR |= 0<<21;                //Peripheral burst transfer configuration
    DMA2_Stream7->CR |= 0<<23;                //Memory burst transfer configuration
    DMA2_Stream7->CR |= 7<<25;                //selection Channel7
60
409
2814
2814
2012-10-17
653 小时
发表于 2016-6-8 09:14:48 | 显示全部楼层
換個說法只有TIM1跟TIM8產生的DMA request 可以拿來給GPIO用
38
38
2013-5-14
发表于 2016-6-8 09:50:44 | 显示全部楼层
也就是说只有DMA2才行了。
38
38
2013-5-14
发表于 2016-6-8 09:53:21 | 显示全部楼层
用TIM3_CH3的输入捕获功能,触发DMA1_Stream7,在设置源地址如果为TIM3的寄存器比如:#define CameraReadAdr (unsigned int)&(TIM3->DIER)
就能触发DMA,能进DMA的传输完成中断,但如果#define CameraReadAdr (unsigned int)&(GPIOA->IDR)就会在DMA就会传输错误
38
38
2013-5-14
发表于 2016-6-8 09:53:59 | 显示全部楼层
有何不可 发表于 2016-6-8 09:53
用TIM3_CH3的输入捕获功能,触发DMA1_Stream7,在设置源地址如果为TIM3的寄存器比如:#define CameraReadA ...
那么GPIOA->IDR算寄存器还是memory
60
409
2814
2814
2012-10-17
653 小时
发表于 2016-6-8 10:03:33 | 显示全部楼层
你沒看到這行嗎@@
60
409
2814
2814
2012-10-17
653 小时
发表于 2016-6-8 10:07:31 | 显示全部楼层
就說了只有DMA2 可以讀寫GPIO底下的register
38
38
2013-5-14
发表于 2016-6-8 11:02:08 | 显示全部楼层
我看了一份资料,说是只有DMA2支持M2M,可是GPIO我觉得是外设,不算是内存吧。
60
409
2814
2814
2012-10-17
653 小时
发表于 2016-6-8 11:38:15 | 显示全部楼层
你可以去問ST....
而且它確實是外設 DMA2_Stream4->CR |= 1<<6;
只是只能透過DMA2訪問的外設...
38
38
2013-5-14
发表于 2016-6-8 11:50:59 | 显示全部楼层
civic7366 发表于 2016-6-8 11:38
你可以去問ST....
好的,谢谢
50
50
2016-9-18
发表于 2016-10-25 17:41:36 | 显示全部楼层
不知道楼主的问题解决没有?这么久了,怎么没下文了?我现在也有这方面的困惑。用的也是407,看过其它类似的应用,却怎么也看不到GPIO口的输出波形,好着急啊
2019-11-14
发表于 2021-3-25 10:06:51 | 显示全部楼层
您好,使用TIM触发DMA修改GPIO的问题解决了吗?我这边也是这个问题@
2019-11-14
发表于 2021-3-25 10:07:35 | 显示全部楼层
是只能使用高级定时器来触发DMA修改GPIO的吗?
2022-6-10
发表于 2022-6-10 16:22:18 | 显示全部楼层
TIM4只能在DMA1上请求DMA,而DMA1的设备主端口只能访问APB1总线上的设备,不能访问AHB总线设备,而所有的GPIO都在AHB设备总线上。
46
46
2023-6-23
发表于 2024-11-7 20:57:48 | 显示全部楼层
还真是至于DMA2可以修改GPIO->ODR,我一开始用定时器2触发DMA1数据转运到 GPIO->ODR改变LED灯的亮灭,但是调了好久没用,后来换成TIM1触发DMA2就可以传输过去控制LED亮灭了
GMT+8, 2026-10-31 10:28
