查看: 12662|回复: 10
STM32F030多路ADC采集有问题
56
208
208
2013-9-23
24 小时
发表于 2016-4-12 16:27:26 | 显示全部楼层 |阅读模式
30金钱
hi,代码如下,STM32F030多路ADC采集,当某一路的电压示数跳变了,会导致另外一个引脚的电压改变,是哪里设置的有问题么?
[mw_shl_code=c,true]void ADC1_DMA_Init1(void)
        ADC_InitTypeDef     ADC_InitStruct;
        DMA_InitTypeDef     DMA_InitStruct;
        GPIO_InitTypeDef    GPIO_InitStruct;
        /* ADC1 DeInit */
        ADC_DeInit(ADC1);
        /* Enable  GPIOA clock */
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
        /* ADC1 Periph clock enable */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
        /* DMA1 clock enable */
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1 , ENABLE);
        RCC_ADCCLKConfig(RCC_ADCCLK_PCLK_Div4);
        /* Configure PA.1  as analog input */
        GPIO_InitStruct.GPIO_Pin = GPIO_Pin_4 |GPIO_Pin_5 | GPIO_Pin_6 |GPIO_Pin_7;
        GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AN;
        GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL ;
        GPIO_Init(GPIOA, &GPIO_InitStruct);
        /* DMA1 Channel1 Config */
        DMA_DeInit(DMA1_Channel1);
        DMA_InitStruct.DMA_PeripheralBaseAddr = (u32)&(ADC1->DR);
        DMA_InitStruct.DMA_MemoryBaseAddr = (u32)RegularConvData_Tab1;
        DMA_InitStruct.DMA_DIR = DMA_DIR_PeripheralSRC;
        DMA_InitStruct.DMA_BufferSize = 4;
        DMA_InitStruct.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
        DMA_InitStruct.DMA_MemoryInc = DMA_MemoryInc_Enable;
        DMA_InitStruct.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
        DMA_InitStruct.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
        DMA_InitStruct.DMA_Mode = DMA_Mode_Circular;
        DMA_InitStruct.DMA_Priority = DMA_Priority_High;
        DMA_InitStruct.DMA_M2M = DMA_M2M_Disable;
        DMA_Init(DMA1_Channel1, &DMA_InitStruct);
        /* DMA1 Channel1 enable */
        DMA_Cmd(DMA1_Channel1, ENABLE);
        /*Enables the specified DMAy Channelx interrupts */
//        DMA_ITConfig(DMA1_Channel1,DMA_IT_TC,ENABLE);
       /* ADC DMA request in circular mode */
        ADC_DMARequestModeConfig(ADC1, ADC_DMAMode_Circular);
       /* Enable ADC_DMA */
        ADC_DMACmd(ADC1, ENABLE);
        /* Initialize ADC structure */
        ADC_StructInit(&ADC_InitStruct);
        /* Configure the ADC1 in continous mode withe a resolutuion equal to 12 bits  */
        ADC_InitStruct.ADC_Resolution  = ADC_Resolution_12b;
        ADC_InitStruct.ADC_ContinuousConvMode  = ENABLE;
        ADC_InitStruct.ADC_ExternalTrigConvEdge  = ADC_ExternalTrigConvEdge_None;
        ADC_InitStruct.ADC_DataAlign  = ADC_DataAlign_Right;
        ADC_InitStruct.ADC_ScanDirection  = ADC_ScanDirection_Backward;
        ADC_Init(ADC1, &ADC_InitStruct);
        ADC_ChannelConfig(ADC1, ADC_Channel_4, ADC_SampleTime_55_5Cycles);
        ADC_ChannelConfig(ADC1, ADC_Channel_5, ADC_SampleTime_55_5Cycles);
        ADC_ChannelConfig(ADC1, ADC_Channel_6, ADC_SampleTime_55_5Cycles);
        ADC_ChannelConfig(ADC1, ADC_Channel_7, ADC_SampleTime_55_5Cycles);
       /* ADCD£×? */
        ADC_GetCalibrationFactor(ADC1);
      /* Enable ADC1 */
       ADC_Cmd(ADC1, ENABLE);
/*       DMA_Cmd(DMA1_Channel1, ENABLE);
      while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_ADRDY));
      /* ADC1 regular Software Start Conv */
      ADC_StartOfConversion(ADC1);
采集:
if(DMA_GetFlagStatus(DMA1_FLAG_TC1) != RESET)
                                 adc_data1[adc_count]=RegularConvData_Tab1[0];
                                 adc_data2[adc_count]=RegularConvData_Tab1[1];
                                 adc_data3[adc_count]=RegularConvData_Tab1[2];
                                 adc_data4[adc_count]=RegularConvData_Tab1[3];
                                 DMA_ClearFlag(DMA1_FLAG_TC1);
                                }[/mw_shl_code]
这个是解决的了。忙着搞毕设没时间,现在补贴上 。。 读RegularConvData_Tab数组就行了,添加通道注意要配置数组与DMA的缓存大小。 [mw_shl_code=c,true]#include "adc.h" #define ADC1_DR_Address 0x40012440 __IO uint16_t RegularConvData_Tab[2]; /* Private typedef -----------------------------------------------------------*/ /* Private define ------------------------------------------------- ...
107
717
717
2014-2-24
257 小时
发表于 2016-4-12 16:27:27 | 显示全部楼层
include 发表于 2016-4-18 16:59
也是用的这个芯片么?
把你代码贴出来看下。
/* Private define ------------------------------------------------------------*/
void ADC1_DMA_Init(void)
  /* Configure PA.01  as analog input */
  GPIO_InitStruct.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
  /* ADC1 DeInit */
  ADC_DeInit(ADC1);
  DMA_InitStruct.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_Address;
  DMA_InitStruct.DMA_MemoryBaseAddr = (uint32_t)&RegularConvData_Tab;
  DMA_InitStruct.DMA_BufferSize = 2;
  ADC_InitStruct.ADC_ScanDirection = ADC_ScanDirection_Upward;
  /* Convert the ADC1 temperature sensor  with 55.5 Cycles as sampling time */
//  ADC_ChannelConfig(ADC1, ADC_Channel_TempSensor , ADC_SampleTime_55_5Cycles);
//  ADC_TempSensorCmd(ENABLE);
  /* Convert the ADC1 Vref  with 55.5 Cycles as sampling time */
   ADC_ChannelConfig(ADC1, ADC_Channel_0|ADC_Channel_1, ADC_SampleTime_71_5Cycles);
  /* ADC Calibration */
  /* Enable ADC1 */
  /* Wait the ADCEN falg */
  while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_ADEN));
}[/mw_shl_code]
91
185
118
118
2016-3-22
122 小时
发表于 2016-4-12 18:54:27 | 显示全部楼层
你代码上分频优点高吧,不能高于14M的,用6分频试试
56
208
208
2013-9-23
24 小时
 楼主| 发表于 2016-4-13 16:26:36 | 显示全部楼层
hi,谢谢您的回复,但是把分频改了之后还是会有这个情况得!~~~
每次接上一个通道,另外一个通道采集到的电压会和原来的采样值不一样
107
717
717
2014-2-24
257 小时
发表于 2016-4-16 11:47:49 | 显示全部楼层
也是奇葩,开启多个通道的时候采样周期239_5没问题,但是改变采样周期的时候通道序号就乱了,数值是能对上。我没用到DMA.
56
208
208
2013-9-23
24 小时
 楼主| 发表于 2016-4-18 16:59:06 | 显示全部楼层
小小怪 发表于 2016-4-16 11:47
也是奇葩,开启多个通道的时候采样周期239_5没问题,但是改变采样周期的时候通道序号就乱了,数值是能对上 ...
也是用的这个芯片么?
把你代码贴出来看下。
457
457
2014-5-7
82 小时
发表于 2018-3-31 02:08:37 | 显示全部楼层
一开始我也弄了好久,我总共要采集4路AD,4路单独采集都没有问题,同时开启只有第一路是正确的,后面3路都是在随机跳。后来在csdn上发现这篇帖子,关键问题在于这个寄存器,“CHSELR”,详细建议看原帖子。https://blog.csdn.net/mrlixirong/article/details/78930275
51
51
2016-6-18
11 小时
发表于 2018-5-16 13:51:31 | 显示全部楼层
祭念草 发表于 2018-3-31 02:08
一开始我也弄了好久,我总共要采集4路AD,4路单独采集都没有问题,同时开启只有第一路是正确的,后面3路都 ...
看到7#的回复,问题解决了,谢谢
252
565
565
2013-10-16
52 小时
发表于 2018-9-7 19:37:09 | 显示全部楼层
看到7#的回复,问题解决了,谢谢谢谢
469
6690
6690
2018-6-27
559 小时
发表于 2019-3-6 14:54:29 | 显示全部楼层
学习学习,学习学习。
150
4147
4147
2016-7-8
843 小时
发表于 2024-11-7 17:06:20 | 显示全部楼层
学习了,特别感谢
GMT+8, 2026-10-31 10:28
