查看: 8858|回复: 1
STM32F302xx STM32F303xx技术手册
38
292
614
614
2012-7-6
发表于 2012-8-9 10:14:59 | 显示全部楼层 |阅读模式
ARM?Cortex-M4 32b MCU+FPU, up to 256KB Flash+48KB SRAM
4 ADCs, 2 DAC ch., 7 comp., 4 PGA, timers, 2.0-3.6 V operation
Datasheet ? preliminary data
Features
■ ARM 32-bit Cortex?-M4 CPU (72 MHz max),
single-cycle multiplication and HW division, DSP
instruction with FPU (floating-point unit) and MPU
(memory protection unit).
■ Operating conditions:
– VDD, VDDA voltage range: 2.0 V to 3.6 V
■ Memories
– 128 to 256 Kbytes of Flash memory
– Up to 40 Kbytes of SRAM on data bus with
HW parity check
– 8 Kbytes of SRAM on instruction bus with HW
parity check (CCM)
■ Clock management
– 4 to 32 MHz crystal oscillator
– 32 kHz oscillator for RTC with calibration
– Internal 8 MHz RC with x 16 PLL option
– Internal 40 kHz oscillator
■ Calendar RTC
– Alarm, periodic wakeup from Stop/Standby
■ Reset and supply management
– Power-on/Power down reset (POR/PDR)
– Programmable voltage detector (PVD)
■ Low power Sleep, Stop, and Standby modes
■ VBAT
 supply for RTC and backup registers
■ Debug mode: serial wire debug (SWD), JTAG
interfaces, Cortex-M4 ETM
■ DMA
– 12-channel DMA controller
– Peripherals supported: timers, ADCs, SPIs,
I
Cs, USARTs and DACs
■ Up to 4 × ADC 0.20 ?S (up to 39 channels) with
selectable resolution of 12/10/8/6 bits, 0 to 3.6 V
conversion range, separate analog supply from 2
to 3.6 V
■ Temperature sensor
■ 7 fast rail-to-rail analog comparators
■ Up to 2 x 12-bit DAC channels
■ Up to 4 operational amplifiers that can be used in
PGA mode, all terminal accessible
■ Support for up to 24 capacitive sensing keys
■ Up to 87 fast I/O ports, all mappable on external
interrupt vectors, several 5 V-tolerant
■ Up to 13 timers
– 1 x 32-bit timer and 2 x 16-bit timers with up
to 4 IC/OC/PWM or pulse counter and
quadrature (incremental) encoder input
– Up to 2 x 16-bit 6-channel advanced-control
timers, with up to 6 PWM channels, deadtime
generation and emergency stop
– 1 x 16-bit timer with 2 IC/OCs, 1 OCN/PWM,
deadtime generation and emergency stop
– 2 x 16-bit timers with IC/OC/OCN/PWM,
– 2 x watchdog timers (independent, window)
– 1 x SysTick timer: 24-bit downcounter
– Up to 2 x 16-bit basic timers to drive the DAC
■ Communication interfaces
– CAN interface (2.0B Active)
– USB 2.0 full speed interface
– 2 x I2C with 20 mA current sink to support
Fast mode plus
– Up to 5 USART/UARTs (ISO 7816 interface,
LIN, IrDA, modem control)
– Up to 3 SPIs, 2 with muxed full-duplex I2S to
achieve audio class accuracy via external
PLL
■ CRC calculation unit, 96-bit unique ID
STM32F302XX.pdf
1.81 MB, 下载次数: 723
STM32F3系列公司现有货供应!STM32F0,STM32F2,STM32F3,STM32F4 银洋电子专业一级代理http://www.y-ec.com 联系电话:021-53086303  淘宝网:http://y-ec.taobao.com
72
104
104
2012-8-3
发表于 2012-8-9 10:55:13 | 显示全部楼层
STM32 F3 选型表
STM32F302CB/  STM32F302CC/  STM32F302RB/  STM32F302RC/  STM32F302VB/  STM32F302VC/  STM32F303CB/STM32F303CC/  STM32F303RB/  STM32F303RC/  STM32F303VB/  STM32F303VC/
STM32F372C8/STM32F372CB/STM32F372CC/STM32F372R8/STM32F372RB/STM32F372RC/STM32F372V8/STM32F372VB/STM32F372VC/
STM32F373C8/STM32F373CB/STM32F373CC/STM32F373R8/STM32F373RB/STM32F373RC/STM32F373V8/STM32F373VB/STM32F373VC
http://www.y-ec.com
http://www.cqqingye.com
GMT+8, 2026-10-23 15:35
