查看: 3928|回复: 1
ARM LPC2366删除某些不想用的全局变量和共用体后,会出现程序跑不起来的情况,求大神解释啊!!
43
43
2016-5-31
11 小时
发表于 2016-5-31 08:41:05 | 显示全部楼层 |阅读模式
43
43
2016-5-31
11 小时
 楼主| 发表于 2016-5-31 10:48:20 | 显示全部楼层
跑死在这个任务里出不来了
static  void  OS_InitTaskIdle (void)
#if OS_TASK_CREATE_EXT_EN > 0
    #if OS_STK_GROWTH == 1
    (void)OSTaskCreateExt(OS_TaskIdle,
                          (void *)0,                                 /* No arguments passed to OS_TaskIdle() */
                          &OSTaskIdleStk[OS_TASK_IDLE_STK_SIZE - 1], /* Set Top-Of-Stack                     */
                          OS_IDLE_PRIO,                              /* Lowest priority level                */
                          OS_TASK_IDLE_ID,
                          &OSTaskIdleStk[0],                         /* Set Bottom-Of-Stack                  */
                          OS_TASK_IDLE_STK_SIZE,
                          (void *)0,                                 /* No TCB extension                     */
                          OS_TASK_OPT_STK_CHK | OS_TASK_OPT_STK_CLR);/* Enable stack checking + clear stack  */
    #else
                          &OSTaskIdleStk[0],                         /* Set Top-Of-Stack                     */
                          OS_TASK_IDLE_ID,
                          &OSTaskIdleStk[OS_TASK_IDLE_STK_SIZE - 1], /* Set Bottom-Of-Stack                  */
    #endif
#else
    (void)OSTaskCreate(OS_TaskIdle,
                       (void *)0,
                       OS_IDLE_PRIO);
    #else
                       (void *)0,
                       &OSTaskIdleStk[0],
                       OS_IDLE_PRIO);
    #endif
#endif
GMT+8, 2026-11-7 00:28
