查看: 8410|回复: 6
RTT-lwip加了dhcp,tcp connect连接不上
2015-6-23
发表于 2016-8-24 16:50:10 | 显示全部楼层 |阅读模式
10金钱
  各位大神好:
   小弟在RT-thread 下创建一个简单的tcp客户端程序,用的是RTT自带的STM32F107程序,网络芯片是DP83848;
   代码如下:
void rt_tcp_client_thread_entry(void* parameter)
        ALIGN(4)
       static const char send_data[] = "this is tcp client from rt-thread.";
        char *recv_data;
        int sock;
        const char server_ip_str[16]="192.168.0.101";
        uint16_t port = 8080;
        struct hostent *host;
        struct in_addr my_ipaddr;
        struct sockaddr_in my_sockaddr;
        int conn;
        recv_data = rt_malloc(1024);
        if(recv_data == RT_NULL)
                 rt_kprintf("no memory\n");
                 return;
        host = gethostbyname(server_ip_str);
        my_ipaddr.s_addr = *(unsigned long *) host->h_addr_list[0];
        rt_kprintf("your IP Address:%s\r\n" , inet_ntoa(my_ipaddr));
        my_sockaddr.sin_family = AF_INET;
        my_sockaddr.sin_port = htons(port);
        my_sockaddr.sin_addr = my_ipaddr;
        rt_memset(&(my_sockaddr.sin_zero), 0, sizeof(my_sockaddr.sin_zero));
        sock = socket(AF_INET, SOCK_STREAM, 0);
        rt_kprintf("sock = %d\n",sock);
        if ( sock == -1 )
                rt_kprintf("Socket error\n");
                rt_free(recv_data);
                return;
        conn =  lwip_connect(sock, (struct sockaddr *)&my_sockaddr, sizeof(struct sockaddr));
        rt_kprintf("conn = %d\n",conn);         if ( conn == -1)
                rt_kprintf("Connect fail!\n");
                lwip_close(sock);
                rt_free(recv_data);
                return;
                                send(sock,send_data,strlen(send_data), 0);
                //                closesocket(sock);
        rt_thread_delay( 500);
   lwip_connect 这个一直返回的是-1,打断点调试sock = 0;
调试进 lwip_connect 进去,
int
lwip_connect(int s, const struct sockaddr *name, socklen_t namelen)
  struct lwip_sock *sock;
  err_t err;
  const struct sockaddr_in *name_in;
  sock = get_socket(s);
  if (!sock) {
    return -1;
   一直返回-1,死在get_socket这个了,这个S传进去是0,但是里面
static struct lwip_sock *
get_socket(int s)
  if ((s < 0) || (s >= NUM_SOCKETS)) {
    LWIP_DEBUGF(SOCKETS_DEBUG, ("get_socket(%d): invalid\n", s));
    set_errno(EBADF);
    return NULL;
  } 直接反馈NULL;
  代码中使能了 RT_LWIP_DHCP;
如果代码不使能 RT_LWIP_DHCP,那么是可以连接上服务器的,但是加了 RT_LWIP_DHCP,一直反馈connect fail,不知道为什么
哪位大哥知道的,指点下,到底哪儿出错了,谢谢!
2015-6-23
 楼主| 发表于 2016-8-24 16:54:43 | 显示全部楼层
软件跑起来后,分配的地址103,我在电脑上ping 192.168.0.103 是可以ping通的,也就是地址是分配了,但是connect..出问题
1043
3752
3752
2011-5-23
2018 小时
发表于 2016-8-24 17:21:19 | 显示全部楼层
先看下当前网络状态
[mw_shl_code=c,true]finsh>>list_if()[/mw_shl_code]
然后板子上面和PC上面都开启数据抓包。
2015-6-23
 楼主| 发表于 2016-8-24 21:08:17 | 显示全部楼层
到connect那进去,sock传进去等于0,然后进入connect函数int
  err_t err;
        rt_kprintf("s = %d\n",s);  //test
  sock = get_socket(s);    0进去,返回的NULL,我看了下,并不满足条件,不知道什么原因;
  if (!sock) {
    return -1;
get_socket(int s)
  if ((s < 0) || (s >= NUM_SOCKETS)) {           S= 0,NUM_SOCKETS =4 ,怎么会进去?????
    set_errno(EBADF);
    return NULL;
list_if()
list_if()
2015-6-23
 楼主| 发表于 2016-8-24 21:12:48 | 显示全部楼层
用wireshark 抓106发过来的包,一包也没有
41
178
178
2017-3-2
51 小时
发表于 2017-10-15 14:49:36 | 显示全部楼层
我也遇到同样的问题,楼主解决了吗?解决了可以分享一下吗?
427
4386
4386
2017-5-30
582 小时
发表于 2018-2-9 17:10:11 | 显示全部楼层
您解决了吗
GMT+8, 2026-11-4 06:12
