查看: 8450|回复: 4
帮忙找一下错误,程序很短。关于接收寄存器到发送寄存器的
106
106
2016-9-12
35 小时
发表于 2016-9-29 19:06:23 | 显示全部楼层 |阅读模式
10金钱
LIBRARY IEEE;
USE IEEE.std_logic_1164.ALL;
USE IEEE.std_logic_unsigned.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
entity hexx is
port (
                        spi_dout : out  STD_LOGIC;
                        spi_clk : in std_logic;
                        clk : in std_logic;
                        spi_rst : in std_logic;
         spi_din : in  STD_LOGIC
end hexx;
architecture behavior of hexx is
signal spi_clk_d1 : std_logic;
signal spi_clk_d2 : std_logic;
signal spi_clk_r_edge : std_logic;
signal spi_clk_f_edge : std_logic;
signal number : integer range 0 to 7;
signal tx_shift_reg : std_logic;
signal rx_shift_reg : std_logic;
begin
    process(clk, spi_rst)
    begin
        if(spi_rst = '1') then
                                number                                  <= 0;
            spi_clk_d1                                     <= '0';
            spi_clk_d2                                     <= '0';
                                tx_shift_reg                            <= (other =>'0');
                                rx_shift_reg                            <= (other =>'0');
                                spi_clk_r_edge                          <= '0';
                                spi_clk_f_edge                          <= '0';
        elsif rising_edge(clk) then
            spi_clk_d1                                     <= spi_clk;
            spi_clk_d2                                     <= spi_clk_d1;
        end if;
    end process;
    spi_clk_r_edge                                  <=  spi_clk_d1 and (not spi_clk_d2);                        --SPI CLK 信号上升沿
    spi_clk_f_edge                                  <=  spi_clk_d2 and (not spi_clk_d1);                        --SPI CLK 信号下降沿
        if(spi_clk_r_edge= '1') then
                if(number = 7) then
                        number                                        <= 0;
                        tx_shift_reg        <= rx_shift_reg(6 downto 0) & spi_din;
                        spi_dout                                      <= rx_shift_reg(7);
                        rx_shift_reg                                  <= rx_shift_reg(6 downto 0) & spi_din;
                   number        <= number + 1;
                end if;
        end if;
         if(spi_clk_f_edge = '1') then
                        spi_dout                                      <= tx_shift_reg(6);
                        tx_shift_reg        <= tx_shift_reg(6 downto 0) & '0';
         end if;
end behavior;
Error (10500): VHDL syntax error at hexx.vhd(45) near text "if";  expecting "end", or "(", or an identifier ("if" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at hexx.vhd(45) near text "then";  expecting "<="
Error (10500): VHDL syntax error at hexx.vhd(46) near text "then";  expecting "<="
Error (10500): VHDL syntax error at hexx.vhd(51) near text "else";  expecting "end", or "(", or an identifier ("else" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at hexx.vhd(54) near text "if";  expecting ";", or an identifier ("if" is a reserved keyword), or "architecture"
Error (10500): VHDL syntax error at hexx.vhd(57) near text "then";  expecting "<="
Error (10500): VHDL syntax error at hexx.vhd(61) near text "if";  expecting ";", or an identifier ("if" is a reserved keyword), or "architecture"
红字的是报的错误和报错的行。感觉有点莫名其妙,if和else对应,看了好久。谢谢大家了
贴出修改后的正确的程序 library ieee; USE IEEE.std_logic_1164.ALL; USE IEEE.std_logic_unsigned.ALL; use IEEE.STD_LOGIC_ARITH.ALL; entity hexx is port ( spi_dout : out STD_LOGIC; spi_clk : in std_logic; clk : in std_logic; spi_rst : in std_logic; spi_din : in STD_LOGIC ); end hexx; architecture behavior of hexx is signal spi_clk_d1 : std_logic; sig ...
106
106
2016-9-12
35 小时
 楼主| 发表于 2016-9-29 19:06:24 | 显示全部楼层
贴出修改后的正确的程序
library ieee;
entity hexx is
port (
                        clk : in std_logic;
end hexx;
signal tx_shift_reg : std_logic_vector(7 downto 0);
signal rx_shift_reg : std_logic_vector(7 downto 0);
begin
    begin
            spi_clk_d1                                     <= '0';
            spi_clk_d2                                     <= '0';
                  end if;
          end process;
    begin
                        number                                  <= 0;
                        tx_shift_reg                            <= (others =>'0');
                        rx_shift_reg                            <= (others =>'0');
                                if (number = 7) then
                                        number                                        <= 0;
                                end if;
                         end if;
                         end if;
                 end if;
                 end process;
end behavior;
106
106
2016-9-12
35 小时
 楼主| 发表于 2016-9-29 19:12:29 | 显示全部楼层
错误不是在信号声明那儿,我知道下面两句错了,但是我改过来还是报一样的错
应该是std_logic_vector(7 downto 0)
165779
165779
发表于 2016-9-29 19:57:28 | 显示全部楼层
59
6303
11899
11899
2014-4-1
1383 小时
发表于 2016-9-30 09:13:31 | 显示全部楼层
不懂VHDL。
不过语法问题还是容易查的。
GMT+8, 2026-10-23 06:00
