查看: 13064|回复: 14
串口2接收中断怎么只能收到第一个字节的数据?
221
496
1246
1246
2013-1-9
123 小时
发表于 2016-10-24 14:22:40 | 显示全部楼层 |阅读模式
用串口2接收发送数据,发送数据正常,接收数据的时候只能接收到第一个字节,比如发送:0x5A 0xA5 0x04 0x83 0x04,0x12,只能收到0x5A,哪位老师帮忙看看问题出在哪儿了?多谢!!!
void uart2_init(u32 bound){
    //GPIO端口设置
    USART_InitTypeDef USART_InitStructure;
   RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO,ENABLE);  //使能GPIOA时钟
   RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);        //使能USART2时钟
     //USART2_TX   PA.2
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //PA.2
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;        //复用推挽输出
    //USART2_RX          PA.3
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入
   //Usart2 NVIC 配置
        NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//抢占优先级3
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;                //子优先级3
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                        //IRQ通道使能
        NVIC_Init(&NVIC_InitStructure);        //根据指定的参数初始化VIC寄存器
   //USART2 初始化设置
        USART_InitStructure.USART_BaudRate = bound;//与DGUS屏通信,设置为115200
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式
        USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位
        USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;        //收发模式
    USART_Init(USART2, &USART_InitStructure); //初始化串口
    USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);//开启接收中断
    USART_Cmd(USART2, ENABLE);                    //使能串口
void USART2_IRQHandler(void)                        //串口2中断服务程序
        if(USART_GetITStatus(USART2, USART_IT_RXNE) != RESET)  //接收中断
                USART_ClearITPendingBit(USART2,USART_IT_RXNE); //清除中断标志.
                Receive_UART2_Buf[Receive_UART2_Pointer] =USART_ReceiveData(USART2);//(USART2->DR);        //读取接收到的数据
                Receive_UART2_Pointer++;
                if(Receive_UART2_Pointer>250)          //如果缓存满,将缓存指针指向缓存的首地址
                        Receive_UART2_Pointer = 0;
175
738
738
2014-7-1
180 小时
发表于 2016-10-24 17:15:23 | 显示全部楼层
定义一个接收缓冲区试试,把接收到的数据先放入一个缓冲区,然后再读出来看看能解决问题不
221
496
1246
1246
2013-1-9
123 小时
 楼主| 发表于 2016-10-24 17:33:03 | 显示全部楼层
Receive_UART2_Buf就是接收缓冲区,能接收不超过250个数据。
221
496
1246
1246
2013-1-9
123 小时
 楼主| 发表于 2016-10-24 17:49:10 | 显示全部楼层
从网上看到有人说每次进一次中断只能接收一个字节,不能在中断里面循环接收数据,是这样的吗?
221
496
1246
1246
2013-1-9
123 小时
 楼主| 发表于 2016-10-24 17:49:40 | 显示全部楼层
那如果连续接收一串数据该怎么处理呢?
221
496
1246
1246
2013-1-9
123 小时
 楼主| 发表于 2016-10-24 18:04:42 | 显示全部楼层
这段程序应该能接收一串数据啊,放在Receive_UART2_Buf[]里。
发表于 2016-10-24 21:24:50 | 显示全部楼层
        if(USART_GetITStatus(USART2, U ...
一次进入中断是接收一个字节,你这个代码看上去没什么问题。
应该是可以接收很多字节才对的,你自己仿真看看吧。
175
738
738
2014-7-1
180 小时
发表于 2016-10-25 08:16:56 | 显示全部楼层
按照原子哥说的做吧,一步一步仿真一下看看
219
598
598
2014-4-14
76 小时
发表于 2016-10-25 08:35:18 | 显示全部楼层
110
553
553
2014-10-23
195 小时
发表于 2016-10-25 11:01:54 | 显示全部楼层
中断是每次都会进吗?
84
529
529
2015-7-21
47 小时
发表于 2016-10-25 12:35:21 | 显示全部楼层
中断里可以连续接收数据,你的Receive_UART2_Buf和Receive_UART2_Pointer是全局的变量,代码没有问题,查一下其他地方吧,中断服务函数应该没问题,Receive_UART2_Pointer这个计数没在其他地方清0吧?
一名合格的工程师一定要做到,代码虐我千百遍依然待她如初恋!
44
148
148
2016-5-17
29 小时
发表于 2017-8-23 17:41:07 | 显示全部楼层
请问你这问题解决了没? 我也遇到一个同样的问题 就是第一次只能接收到一个字节 第二次就可以正常的接收了  如果第一次发送超过一个字节就卡死了
56
518
963
963
2014-11-18
160 小时
发表于 2017-8-24 13:56:51 | 显示全部楼层
STM32初学~zy 发表于 2017-8-23 17:41
请问你这问题解决了没? 我也遇到一个同样的问题 就是第一次只能接收到一个字节 第二次就可以正常的接收了  ...
我教你怎么验证, 你试试我的思路就知道了
做一个最后一个字节判断的程序,即全部接收完一整个数据包才开始打印.
思路比较简单,定义一个全局变量,初始化为10ms(看你定时器中断进去一次多少时间)
串口接收中断每次进去以后更新为10ms,  定时器那边每次进入--,if为0了  说明全部接收完成
标志位置1,然后打印数据包,清零,进行下次.
自己选择的路,成家前走完。
81
1002
1876
1876
2014-9-10
208 小时
发表于 2017-8-24 14:15:44 | 显示全部楼层
Ctrl+f,全工程搜索:
搜索数组名和下标名 Receive_UART2_Buf[Receive_UART2_Pointer] ,哪里用了?
搜索接收中断,哪里关了?
跟踪第一次收到后程序跑哪里去了?是不是不再进入中断?
小小蜗牛
46
46
2017-7-8
发表于 2017-8-24 14:58:29 | 显示全部楼层
串口中断的原理是,如果来八个字节的数据,要进八次中断,每次进中断读取一个字节
GMT+8, 2026-10-31 04:38
