查看: 7757|回复: 2
spi屏幕驱动
156
265
907
907
2012-6-29
41 小时
发表于 2016-10-26 12:58:52 | 显示全部楼层 |阅读模式
spi屏幕驱动在stm32上无论是通过硬件spi还是软件模拟都是可以点亮屏幕,  但是我移植到stm8s上后,只有模拟的点亮 硬件spi没有点亮,帮忙看看什么原因, 谢谢
stm8设为推挽输出的波形是方波  下面那个是stm32 sck  跟mosi的波形
STM8 SPI设置
void SPI1_Init(void)
    GPIO_DeInit(GPIOC);
    GPIO_Init(GPIOC, GPIO_PIN_1, GPIO_MODE_OUT_PP_HIGH_FAST);
    GPIO_Init(GPIOC, GPIO_PIN_2, GPIO_MODE_OUT_PP_HIGH_FAST);
    GPIO_Init(GPIOC, GPIO_PIN_3, GPIO_MODE_OUT_PP_HIGH_FAST);
    GPIO_Init(GPIOC, GPIO_PIN_4, GPIO_MODE_OUT_PP_HIGH_FAST);
   //GPIO_Init(GPIOC, GPIO_PIN_6, GPIO_MODE_OUT_PP_HIGH_FAST);
    SPI->CR1 = (0<<7)|(0<<6)|(0<<3)|(1<<2)|(1<<1)|(1<<0);  /* 先发送MSB 先禁止SPI 波特率设为 fbus/2 设置为主模式 空闲状态时SCK为高电平 数据从第二个时钟边沿开始采样 */
  SPI->CR2 = (0<<7)|(0<<5)|(0<<4)|(0<<2)|(1<<1)|(1<<0);  /* 设为全双工模式 使能软件从设备管理 内部从设备选择为主模式 */
  SPI->ICR = (0<<7)|(0<<6)|(0<<5)|(0<<4);                /* 禁止所有中断 */
  SPI->CR1 |= (1<<6);                                    /* 开启SPI模块 */
   // SPI_Init(SPI_FIRSTBIT_MSB, SPI_BAUDRATEPRESCALER_2, SPI_MODE_MASTER, SPI_CLOCKPOLARITY_HIGH, SPI_CLOCKPHASE_2EDGE, SPI_DATADIRECTION_2LINES_FULLDUPLEX, SPI_NSS_HARD, 0x07);
   // SPI_Cmd(ENABLE);
  //发送一个数据
u8 SPI_WriteByte(u8 Byte)
  while(!(SPI->SR & 0x02));              /* 等待发送寄存器为空 */
  SPI->DR = Byte;                        /* 将发送的数据写到数据寄存器 */
  while(!(SPI->SR & 0x01));              /* 等待接受寄存器满 */
  return SPI->DR;                        /* 读数据寄存器 */
stm32 spi设置
void SPI2_Init(void)
SPI_InitTypeDef  SPI_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO|RCC_APB2Periph_GPIOB, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_15;
GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_14;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9|GPIO_Pin_10| GPIO_Pin_11| GPIO_Pin_12;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2 ,ENABLE);
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI2, &SPI_InitStructure);
SPI_Cmd(SPI2, ENABLE);
  //发送一个数据
u8 SPI_WriteByte(SPI_TypeDef* SPIx,u8 Byte)
while((SPIx->SR&SPI_I2S_FLAG_TXE)==RESET);  //&micro;&Egrave;&acute;&yacute;·&cent;&Euml;&Iacute;&Ccedil;&oslash;&iquest;&Otilde;
SPIx->DR=Byte;   //·&cent;&Euml;&Iacute;&Ograve;&raquo;&cedil;&ouml;byte
while((SPIx->SR&SPI_I2S_FLAG_RXNE)==RESET);//&micro;&Egrave;&acute;&yacute;&frac12;&Oacute;&Ecirc;&Otilde;&Iacute;ê&Ograve;&raquo;&cedil;&ouml;byte
return SPIx->DR;                //·&micro;&raquo;&Oslash;&Ecirc;&Otilde;&micro;&frac12;&micro;&Auml;&Ecirc;&yacute;&frac34;&Yacute;
stm32 的波形 SCK 跟mosi
stm32 的波形 SCK 跟mosi
286
2062
2062
2012-5-26
292 小时
发表于 2016-10-26 13:47:22 | 显示全部楼层
可以用示波器看一下波形有什么不同?
活着才是王道!健康是一切的前提!
156
265
907
907
2012-6-29
41 小时
 楼主| 发表于 2016-10-26 17:06:29 | 显示全部楼层
lison0103 发表于 2016-10-26 13:47
可以用示波器看一下波形有什么不同?
波形图上传了  ,麻烦看看 stm8的波形是方波
GMT+8, 2026-10-24 09:43
