查看: 3611|回复: 1
BH1750 FPGA VHDL程序一直无输出,求大神帮助
2016-11-19
发表于 2016-11-19 17:47:01 | 显示全部楼层 |阅读模式
程序如下:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity adc is
    Port ( adc_out : out  STD_LOGIC_vector(15 downto 0);
           SCL : out  STD_LOGIC;
           SDA : inout  STD_LOGIC;
           clk50MHz : in  STD_LOGIC;
           adc_en : in  STD_LOGIC);
end adc;
architecture Behavioral of adc is
constant slaveaddress : std_logic_vector(7 downto 0):=x"46";  ------------write address-----------------
constant slaveaddress2 :std_logic_vector(7 downto 0) := x"47";   ---------read address---------------
constant h_resolution_mode :std_logic_vector(7 downto 0) := x"10";
constant poweron : std_logic_vector(7 downto 0) := x"01";
signal delay5us : std_logic_vector(7 downto 0);
type state is (step1,step2,step3,step4,step5,step6,step7,step8,step9,step10,step11,step12,step13,step14,
step15,step16,step17,step18,step19,step20,step21,step22,step23,step24,step25,step26,step27,step28,step29,step30,
step31,step32,step33,step34,step35,step36,step37,step38,step39,step40,step42,step43,step44,step45,step46,step47,
stepplu1,stepplu2,stepplu3,stepplu4,stepplua1,stepplua2,stepplua3,stepplua4,stepplub1,stepplub2,stepplub3,stepplub4,
steppluc1,steppluc2,steppluc3,steppluc4,stepplud1,stepplud2,stepplud3,stepplud4);
type state_send is(a1,a2,a3,a4);
signal state2 : state_send ;
signal state1 : state;
signal counter : integer range 0 to 7;
signal delay180ms : std_logic_vector(23 downto 0);
type state_receive is (b1,b2,b3,b4,b5);
signal state3 :state_receive ;
signal counter2 : integer range 8 to 15;
signal temp : std_logic_vector(15 downto 0);
signal delay5ms :std_logic_vector(7 downto 0);
signal counter3 :integer range 0 to 7;
begin
process(clk50MHz,adc_en)
begin
        if adc_en='1' then
                if clk50MHz' event and clk50MHz='1' then
                        case state1 is
                        when step1 =>   ---------start-------------
                                SDA<='1';
                                SCL<='1';
                                state1<=step2;
                        when step2 =>   -----------delay-----------------
                                if delay5us=x"FA" then
                                        state1<=step3;
                                        delay5us<=x"00";
                                        delay5us<=delay5us+1;
                                end if;------------------------------------------
                        when step3 =>
                                SDA<= '0';
                                state1 <=step4;
                        when step4 =>
                                        state1<=step5;
                                        delay5us<=x"00";
                                end if;
                        when step5 =>
                                SCL<='0';
                                state1<=step6;    -----------over--------------------
                        when step6 =>        ----------send slaveaddress+write signal-------
                                        case state2 is
                                        when a1 =>
                                                SDA<=slaveaddress(counter);
                                                SCL<='1';
                                                state2<=a2;
                                        when a2 =>
                                                        state2<=a3;
                                                        delay5us<=x"00";
                                                end if;
                                        when a3 =>
                                                SCL<='0';
                                                state2<=a4;
                                        when a4=>
                                                        if counter = 0 then
        state1<=stepplu1;
        counter<=7;
        state2<=a1;
        delay5us<=x"00";
        counter<=counter-1;
        state2<=a1;
        delay5us<=x"00";
                                                        end if;
                                                end if;
                                        end case;   -----------over---------------------
                        when stepplu1=>   -----------receive ACK--------------
                                SCL<='1';
                                state1<=stepplu2;
                        when stepplu2=>
                                        state1<=stepplu3;
                                        delay5us<=x"00";
                                end if;
                        when stepplu3=>
                                SCL<='0';
                                state1<=stepplu4;
                        when stepplu4=>
                                        state1<=step7;
                                        delay5us<=x"00";
                                end if;       -----------over----------------------
                        when step7 =>    -------------send power on signal--------------
                                        case state2 is
                                        when a1 =>
                                                SDA<=poweron(counter);
                                                SCL<='1';
                                                state2<=a2;
                                        when a2 =>
                                                        state2<=a3;
                                                        delay5us<=x"00";
                                                end if;
                                        when a3 =>
                                                SCL<='0';
                                                state2<=a4;
                                        when a4=>
                                                        if counter=0 then
        state1<= stepplua1;
        counter<=7;
        state2<=a1;
        delay5us<=x"00";
        counter<=counter-1;
        state2<=a1;
        delay5us<=x"00";
                                                        end if;
                                                end if;
                                        end case;   ------------------over--------------------
                        when stepplua1=>   -----------receive ACK--------------
                                SCL<='1';
                                state1<=stepplua2;
                        when stepplua2=>
                                        state1<=stepplua3;
                                        delay5us<=x"00";
                                end if;
                        when stepplua3=>
                                SCL<='0';
                                state1<=stepplua4;
                        when stepplua4=>
                                        state1<=step8;
                                        delay5us<=x"00";
                        when step8 =>      ---------------stop----------------------
                                SDA<='0';
                                SCL<='1';
                                state1<=step9;
                        when step9 =>
                                        state1<=step10;
                                        delay5us<=x"00";
                                end if;
                        when step10 =>
                                SDA<='1';
                                state1<=step11;
                        when step11 =>
                                        state1<=step12;
                                        delay5us<=x"00";
                                end if;        -----------------over------------------------
                        when step12 => -----------------start---------------------
                                SDA<='1';
                                SCL<='1';
                                state1<=step13;
                        when step13 =>
                                        state1<=step14;
                                        delay5us<=x"00";
                                end if;
                        when step14 =>
                                SDA<= '0';
                                state1 <=step15;
                        when step15 =>
                                        state1<=step16;
                                        delay5us<=x"00";
                                end if;
                        when step16 =>
                                SCL<='0';
                                state1<=step17;   -------------------over---------------------
                        when step17 =>       ----------------send slaveaddress+write signal-------
                                        case state2 is
                                        when a1 =>
                                                SCL<='1';
                                                state2<=a2;
                                        when a2 =>
                                                        state2<=a3;
                                                        delay5us<=x"00";
                                                end if;
                                        when a3 =>
                                                SCL<='0';
                                                state2<=a4;
                                        when a4=>
                                                        if counter = 0 then
        state1<= stepplub1;
        counter<=7;
        state2<=a1;
        delay5us<=x"00";
        counter<=counter-1;
        state2<=a1;
        delay5us<=x"00";
                                                        end if;
                                                end if;
                                        end case;  -------------------------over---------------
                        when stepplub1=>   -----------receive ACK--------------
                                SCL<='1';
                                state1<=stepplub2;
                        when stepplub2=>
                                        state1<=stepplub3;
                                        delay5us<=x"00";
                                end if;
                        when stepplub3=>
                                SCL<='0';
                                state1<=stepplub4;
                        when stepplub4=>
                                        state1<=step18;
                                        delay5us<=x"00";
                        when step18 =>   ----------send  H- resolution mode signal-------
                                        case state2 is
                                        when a1 =>
                                                SDA<=h_resolution_mode(counter);
                                                SCL<='1';
                                                state2<=a2;
                                        when a2 =>
                                                        state2<=a3;
                                                        delay5us<=x"00";
                                                end if;
                                        when a3 =>
                                                SCL<='0';
                                                state2<=a4;
                                        when a4=>
                                                        if counter=0 then
        state1<= steppluc1;
        counter<=7;
        state2<=a1;
        delay5us<=x"00";
        counter<=counter-1;
        state2<=a1;
        delay5us<=x"00";
                                                        end if;
                                                end if;
                        when steppluc1=>   -----------receive ACK--------------
                                SCL<='1';
                                state1<=steppluc2;
                        when steppluc2=>
                                        state1<=steppluc3;
                                        delay5us<=x"00";
                                end if;
                        when steppluc3=>
                                SCL<='0';
                                state1<=steppluc4;
                        when steppluc4=>
                                        state1<=step19;
                                        delay5us<=x"00";
                        when step19 =>  -------------stop--------------
                                SDA<='0';
                                SCL<='1';
                                state1<=step20;
                        when step20 =>
                                        state1<=step21;
                                        delay5us<=x"00";
                                end if;
                        when step21 =>
                                SDA<='1';
                                state1<=step22;
                        when step22 =>
                                        state1<=step23;
                                        delay5us<=x"00";
                                end if;    ------------------over----------------
                        when step23 =>   -------------delay 180 ms ----------
                                if delay180ms=x"895440" then
                                        state1<=step24;
                                        delay180ms<=x"000000";
                                        delay180ms<=delay180ms+1;
                                end if;        ------------over-----------------
                        when step24 =>   ---------start-----------------------
                                SDA<='1';
                                SCL<='1';
                                state1<=step25;
                        when step25 =>
                                        state1<=step26;
                                        delay5us<=x"00";
                                end if;
                        when step26 =>
                                SDA<= '0';
                                state1 <=step27;
                        when step27 =>
                                        state1<=step28;
                                        delay5us<=x"00";
                                end if;
                        when step28 =>
                                SCL<='0';
                                state1<=step29;    -----------over-----------------
                        when step29 =>        -----------send slaveaddress+read signal---------
                                        case state2 is
                                        when a1 =>
                                                SDA<=slaveaddress2(counter);
                                                SCL<='1';
                                                state2<=a2;
                                        when a2 =>
                                                        state2<=a3;
                                                        delay5us<=x"00";
                                                end if;
                                        when a3 =>
                                                SCL<='0';
                                                state2<=a4;
                                        when a4=>
                                                        if counter=0 then
        state1<= stepplud1;
        counter<=7;
        state2<=a1;
        delay5us<=x"00";
        counter<=counter-1;
        state2<=a1;
        delay5us<=x"00";
                                                        end if;
                                                end if;
                                        end case;    ------------over-----------------
                        when stepplud1=>   -----------receive ACK--------------
                                SCL<='1';
                                state1<=stepplud2;
                        when stepplud2=>
                                        state1<=stepplud3;
                                        delay5us<=x"00";
                                end if;
                        when stepplud3=>
                                SCL<='0';
                                state1<=stepplud4;
                        when stepplud4=>
                                        state1<=step30;
                                        delay5us<=x"00";
                        when step30 =>       ------------------receive h data------------------------
                                SDA<='1';
                                state1<=step31;
                        when step31 =>
                                        case state3 is
                                        when b1 =>
                                                SCL<='1';
                                                state3<=b2;
                                        when b2 =>
                                                        state3<=b3;
                                                        delay5us<=x"00";
                                                end if;
                                        when b3 =>
                                                temp(counter2)<=SDA;
                                                state3<=b4;
                                        when b4 =>
                                                SCL<='0';
                                                state3<=b5;
                                        when b5 =>
                                                        if counter2=8 then
        state1<=step42;
        counter2<=15;
        delay5us<=x"00";
        state3<=b1;
        state3<=b1;
        counter2<=counter2-1;
        delay5us<=x"00";
                                                        end if;
                                                end if;
                                        end case;        ----------------over----------------
                        when step42 =>         ----------------Ack=0------------------------------
                                SDA<='0';
                                SCL<='1';
                                state1<=step43;
                        when step43 =>
                                        state1<=step44;
                                        delay5us<=x"00";
                                end if;
                        when step44 =>
                                SCL<='0';
                                state1<=step45;
                        when step45 =>
                                        state1<=step46;
                                        delay5us<=x"00";
                                end if;                     ----------------over--------------
                        when step46 =>              -------------receive  low data----------------
                                SDA<='1';
                                state1<=step47;
                        when step47 =>
                                        case state3 is
                                        when b1 =>
                                                SCL<='1';
                                                state3<=b2;
                                        when b2 =>
                                                        state3<=b3;
                                                        delay5us<=x"00";
                                                end if;
                                        when b3 =>
                                                temp(counter3)<=SDA;
                                                state3<=b4;
                                        when b4 =>
                                                SCL<='0';
                                                state3<=b5;
                                        when b5 =>
                                                        if counter3 = 0 then
        state1<=step32;
        counter3<=7;
        delay5us<=x"00";
        state3<=b1;
        counter3<=counter3-1;
        delay5us<=x"00";
        state3<=b1;
                                                        end if;
                                                end if;
                                        end case;      -----------------over-------------------
                        when step32 =>      -----------------ACK=1------------------
                                SDA<='1';
                                SCL<='1';
                                state1<=step33;
                        when step33 =>
                                        state1<=step34;
                                        delay5us<=x"00";
                                end if;
                        when step34 =>
                                SCL<='0';
                                state1<=step35;
                        when step35 =>
                                        state1<=step36;
                                        delay5us<=x"00";
                                end if;
                        when step36 =>            --------------stop--------------
                                SDA<='0';
                                SCL<='1';
                                state1<=step37;
                        when step37 =>
                                        state1<=step38;
                                        delay5us<=x"00";
                                end if;
                        when step38 =>
                                SDA<='1';
                                state1<=step39;
                        when step39 =>
                                        state1<=step40;
                                        delay5us<=x"00";
                        when step40 =>     ---------------delay 5 ms------------
                                if delay5ms=x"64" then
                                        state1<=step1;
                                        delay5ms<=x"00";
                                        delay5ms<=delay5ms+1;
                                end if;         --------------over-----------------
                        end case;
                end if;
                adc_out<=temp;
state1<=step1;
state2<=a1;
counter<=7;
state3<=b1;
counter2<=15;
counter3<=7;
delay5ms<=x"00";
temp<=x"0000";
SDA<='1';
SCL<='1';
delay5us<=x"00";
adc_out<=X"0000";
end if;
end process;
end Behavioral;
165779
165779
发表于 2016-11-20 19:15:29 | 显示全部楼层
GMT+8, 2026-10-22 05:19
