查看: 5654|回复: 2
【LWIP_F4】怎么解决tcp重传?我心跳信号的延迟超了
106
106
2016-11-15
24 小时
发表于 2016-12-6 09:20:59 | 显示全部楼层 |阅读模式
10金钱
STM32F407板子做lwip tcp客户端,一根网线直连电脑,老是会超时重传,心跳过不去,最大心跳延时超过了300ms,平时只有1ms不到
群里的大神们,@正点原子 原子哥帮忙看看吧,折磨几天了。
怎么去 解决掉 重传 或者 让心跳延时 稳定在100ms或者10ms以内?
以下都是在上位机网卡抓的包和 做的心跳统计
重传
重传
中间也出现过TCP duplicate ack  和 spurious retransmission
Dup Ack
Dup Ack
心跳时间 统计
  start : 26021236.439 ,end : 26021237.336 Time Elapse:0.897 max Elapse :255.062
  start : 26023736.330 ,end : 26023737.330 Time Elapse:1.000 max Elapse :255.062
  start : 26026236.209 ,end : 26026237.164 Time Elapse:0.955 max Elapse :255.062
  start : 26028736.138 ,end : 26028737.089 Time Elapse:0.952 max Elapse :255.062
  start : 26031235.980 ,end : 26031236.983 Time Elapse:1.003 max Elapse :255.062
  start : 26033735.880 ,end : 26033736.829 Time Elapse:0.949 max Elapse :255.062
  start : 26036235.830 ,end : 26036236.875 Time Elapse:1.045 max Elapse :255.062
  start : 26038735.714 ,end : 26038736.679 Time Elapse:0.965 max Elapse :255.062
  start : 26041235.660 ,end : 26041236.646 Time Elapse:0.986 max Elapse :255.062
  start : 26043735.504 ,end : 26043938.344 Time Elapse:202.839 max Elapse :255.062
  start : 26046235.435 ,end : 26046236.426 Time Elapse:0.991 max Elapse :255.062
  start : 26048735.369 ,end : 26048736.419 Time Elapse:1.051 max Elapse :255.062
  start : 26051235.226 ,end : 26051236.187 Time Elapse:0.961 max Elapse :255.062
  start : 26053735.135 ,end : 26053736.113 Time Elapse:0.977 max Elapse :255.062
  start : 26056235.021 ,end : 26056236.132 Time Elapse:1.111 max Elapse :255.062
  start : 26058734.930 ,end : 26058735.892 Time Elapse:0.962 max Elapse :255.062
  start : 26061234.905 ,end : 26061235.931 Time Elapse:1.026 max Elapse :255.062
  start : 26063734.735 ,end : 26063735.705 Time Elapse:0.970 max Elapse :255.062
  start : 26066234.701 ,end : 26066235.727 Time Elapse:1.027 max Elapse :255.062
  start : 26068734.643 ,end : 26068735.679 Time Elapse:1.035 max Elapse :255.062
  start : 26071234.454 ,end : 26071235.417 Time Elapse:0.963 max Elapse :255.062
  start : 26073734.351 ,end : 26073735.356 Time Elapse:1.005 max Elapse :255.062
  start : 26076234.317 ,end : 26076235.389 Time Elapse:1.072 max Elapse :255.062
  start : 26078734.259 ,end : 26078735.329 Time Elapse:1.070 max Elapse :255.062
  start : 26081234.087 ,end : 26081234.916 Time Elapse:0.830 max Elapse :255.062
  start : 26083733.975 ,end : 26083735.005 Time Elapse:1.030 max Elapse :255.062
  start : 26086233.936 ,end : 26086234.979 Time Elapse:1.043 max Elapse :255.062
  start : 26088733.782 ,end : 26088734.745 Time Elapse:0.964 max Elapse :255.062
  start : 26091233.771 ,end : 26091234.718 Time Elapse:0.947 max Elapse :255.062
  start : 26093733.646 ,end : 26093734.667 Time Elapse:1.021 max Elapse :255.062
  start : 26096233.548 ,end : 26096234.594 Time Elapse:1.046 max Elapse :255.062
  start : 26098733.395 ,end : 26098734.359 Time Elapse:0.964 max Elapse :255.062
  start : 26101233.326 ,end : 26101234.279 Time Elapse:0.953 max Elapse :255.062
  start : 26103733.196 ,end : 26103734.162 Time Elapse:0.966 max Elapse :255.062
  start : 26106233.098 ,end : 26106234.076 Time Elapse:0.978 max Elapse :255.062
  start : 26108733.079 ,end : 26108734.132 Time Elapse:1.053 max Elapse :255.062
  start : 26111232.992 ,end : 26111234.076 Time Elapse:1.084 max Elapse :255.062
  start : 26113732.839 ,end : 26113733.791 Time Elapse:0.952 max Elapse :255.062
  start : 26116232.776 ,end : 26116233.803 Time Elapse:1.027 max Elapse :255.062
  start : 26118732.693 ,end : 26118733.543 Time Elapse:0.850 max Elapse :255.062
  start : 26121232.532 ,end : 26121233.469 Time Elapse:0.937 max Elapse :255.062
  start : 26123732.457 ,end : 26123733.461 Time Elapse:1.003 max Elapse :255.062
  start : 26126232.409 ,end : 26126233.431 Time Elapse:1.022 max Elapse :255.062
  start : 26128732.354 ,end : 26128733.412 Time Elapse:1.058 max Elapse :255.062
  start : 26131232.200 ,end : 26131233.133 Time Elapse:0.933 max Elapse :255.062
  start : 26133732.041 ,end : 26133817.006 Time Elapse:84.964 max Elapse :255.062
  start : 26136231.997 ,end : 26136233.051 Time Elapse:1.054 max Elapse :255.062
  start : 26138731.940 ,end : 26138732.975 Time Elapse:1.036 max Elapse :255.062
  start : 26141231.896 ,end : 26141232.904 Time Elapse:1.009 max Elapse :255.062
  start : 26143731.663 ,end : 26143732.639 Time Elapse:0.976 max Elapse :255.062
  start : 26146231.579 ,end : 26146232.512 Time Elapse:0.933 max Elapse :255.062
  start : 26148731.484 ,end : 26148732.445 Time Elapse:0.962 max Elapse :255.062
  start : 26151231.376 ,end : 26151232.317 Time Elapse:0.941 max Elapse :255.062
  start : 26153731.288 ,end : 26153732.213 Time Elapse:0.926 max Elapse :255.062
  start : 26156231.269 ,end : 26156232.276 Time Elapse:1.007 max Elapse :255.062
  start : 26158731.094 ,end : 26158732.103 Time Elapse:1.009 max Elapse :255.062
  start : 26161231.034 ,end : 26161232.067 Time Elapse:1.033 max Elapse :255.062
  start : 26163730.967 ,end : 26163731.979 Time Elapse:1.012 max Elapse :255.062
  start : 26166230.897 ,end : 26166231.871 Time Elapse:0.974 max Elapse :255.062
  start : 26168730.711 ,end : 26168731.698 Time Elapse:0.987 max Elapse :255.062
  start : 26171230.644 ,end : 26171231.619 Time Elapse:0.975 max Elapse :255.062
  start : 26173730.524 ,end : 26173731.504 Time Elapse:0.981 max Elapse :255.062
  start : 26176230.426 ,end : 26176231.434 Time Elapse:1.008 max Elapse :255.062
  start : 26178730.341 ,end : 26178731.296 Time Elapse:0.954 max Elapse :255.062
  start : 26181230.279 ,end : 26181231.357 Time Elapse:1.078 max Elapse :255.062
  start : 26183730.258 ,end : 26183731.328 Time Elapse:1.070 max Elapse :255.062
  start : 26186230.075 ,end : 26186231.130 Time Elapse:1.056 max Elapse :255.062
  start : 26188730.043 ,end : 26188731.068 Time Elapse:1.026 max Elapse :255.062
  start : 26191229.919 ,end : 26191230.961 Time Elapse:1.041 max Elapse :255.062
  start : 26193729.811 ,end : 26193730.797 Time Elapse:0.986 max Elapse :255.062
  start : 26196229.774 ,end : 26196230.824 Time Elapse:1.050 max Elapse :255.062
  start : 26198729.587 ,end : 26198730.551 Time Elapse:0.964 max Elapse :255.062
  start : 26201229.545 ,end : 26201230.621 Time Elapse:1.075 max Elapse :255.062
  start : 26203729.358 ,end : 26203730.351 Time Elapse:0.992 max Elapse :255.062
  start : 26206229.375 ,end : 26206230.417 Time Elapse:1.042 max Elapse :255.062
  start : 26208729.183 ,end : 26208730.065 Time Elapse:0.883 max Elapse :255.062
  start : 26211229.087 ,end : 26211230.054 Time Elapse:0.967 max Elapse :255.062
  start : 26213729.066 ,end : 26213730.125 Time Elapse:1.059 max Elapse :255.062
  start : 26216228.967 ,end : 26216229.973 Time Elapse:1.007 max Elapse :255.062
  start : 26218728.788 ,end : 26218729.760 Time Elapse:0.973 max Elapse :255.062
  start : 26221228.753 ,end : 26221229.708 Time Elapse:0.955 max Elapse :255.062
  start : 26223728.598 ,end : 26223814.433 Time Elapse:85.835 max Elapse :255.062
  start : 26226228.529 ,end : 26226229.528 Time Elapse:1.000 max Elapse :255.062
  start : 26228728.412 ,end : 26228729.349 Time Elapse:0.937 max Elapse :255.062
  start : 26231228.479 ,end : 26231229.524 Time Elapse:1.045 max Elapse :255.062
  start : 26233728.280 ,end : 26233729.305 Time Elapse:1.025 max Elapse :255.062
  start : 26236228.194 ,end : 26236229.165 Time Elapse:0.971 max Elapse :255.062
  start : 26238728.035 ,end : 26238728.968 Time Elapse:0.932 max Elapse :255.062
  start : 26241227.987 ,end : 26241228.988 Time Elapse:1.000 max Elapse :255.062
  start : 26243727.860 ,end : 26243728.790 Time Elapse:0.930 max Elapse :255.062
  start : 26246227.760 ,end : 26246228.737 Time Elapse:0.977 max Elapse :255.062
  start : 26248727.674 ,end : 26248728.601 Time Elapse:0.927 max Elapse :255.062
  start : 26251227.641 ,end : 26251228.679 Time Elapse:1.038 max Elapse :255.062
  start : 26253727.577 ,end : 26253728.603 Time Elapse:1.026 max Elapse :255.062
  start : 26256227.547 ,end : 26256228.591 Time Elapse:1.043 max Elapse :255.062
  start : 26258727.260 ,end : 26258728.362 Time Elapse:1.103 max Elapse :255.062
  start : 26261227.175 ,end : 26261228.227 Time Elapse:1.051 max Elapse :255.062
  start : 26263727.104 ,end : 26263728.157 Time Elapse:1.053 max Elapse :255.062
  start : 26266226.980 ,end : 26266227.990 Time Elapse:1.010 max Elapse :255.062
  start : 26268726.881 ,end : 26268727.848 Time Elapse:0.966 max Elapse :255.062
  start : 26271226.824 ,end : 26271227.776 Time Elapse:0.952 max Elapse :255.062
  start : 26273726.718 ,end : 26273727.725 Time Elapse:1.007 max Elapse :255.062
  start : 26276226.651 ,end : 26276227.686 Time Elapse:1.035 max Elapse :255.062
  start : 26278726.578 ,end : 26278727.526 Time Elapse:0.947 max Elapse :255.062
  start : 26281226.427 ,end : 26281227.574 Time Elapse:1.148 max Elapse :255.062
  start : 26283726.414 ,end : 26283727.465 Time Elapse:1.051 max Elapse :255.062
  start : 26286226.263 ,end : 26286227.204 Time Elapse:0.942 max Elapse :255.062
  start : 26288726.096 ,end : 26288727.088 Time Elapse:0.993 max Elapse :255.062
  start : 26291226.088 ,end : 26291227.111 Time Elapse:1.023 max Elapse :255.062
  start : 26293725.941 ,end : 26293726.929 Time Elapse:0.988 max Elapse :255.062
  start : 26296225.851 ,end : 26296226.904 Time Elapse:1.053 max Elapse :255.062
  start : 26298725.793 ,end : 26298726.819 Time Elapse:1.027 max Elapse :255.062
  start : 26301225.691 ,end : 26301226.722 Time Elapse:1.032 max Elapse :255.062
  start : 26303725.638 ,end : 26303726.672 Time Elapse:1.033 max Elapse :255.062
  start : 26306225.516 ,end : 26306226.567 Time Elapse:1.051 max Elapse :255.062
  start : 26308725.410 ,end : 26308726.472 Time Elapse:1.062 max Elapse :255.062
  start : 26311225.250 ,end : 26311226.221 Time Elapse:0.971 max Elapse :255.062
  start : 26313725.221 ,end : 26313923.073 Time Elapse:197.852 max Elapse :255.062
  start : 26316225.158 ,end : 26316226.152 Time Elapse:0.994 max Elapse :255.062
  start : 26318724.963 ,end : 26318725.859 Time Elapse:0.896 max Elapse :255.062
  start : 26321224.917 ,end : 26321225.951 Time Elapse:1.034 max Elapse :255.062
  start : 26323724.796 ,end : 26323725.804 Time Elapse:1.008 max Elapse :255.062
  start : 26326224.701 ,end : 26326225.711 Time Elapse:1.010 max Elapse :255.062
  start : 26328724.582 ,end : 26328725.504 Time Elapse:0.922 max Elapse :255.062
  start : 26331224.488 ,end : 26331225.461 Time Elapse:0.973 max Elapse :255.062
  start : 26333724.412 ,end : 26333725.356 Time Elapse:0.943 max Elapse :255.062
  start : 26336224.295 ,end : 26336225.219 Time Elapse:0.924 max Elapse :255.062
  start : 26338724.191 ,end : 26338725.141 Time Elapse:0.950 max Elapse :255.062
  start : 26341224.159 ,end : 26341225.201 Time Elapse:1.042 max Elapse :255.062
  start : 26343724.007 ,end : 26343725.105 Time Elapse:1.099 max Elapse :255.062
  start : 26346223.913 ,end : 26346224.989 Time Elapse:1.076 max Elapse :255.062
  start : 26348723.816 ,end : 26348724.780 Time Elapse:0.964 max Elapse :255.062
  start : 26351223.783 ,end : 26351224.809 Time Elapse:1.026 max Elapse :255.062
  start : 26353723.646 ,end : 26353724.611 Time Elapse:0.964 max Elapse :255.062
  start : 26356223.555 ,end : 26356224.498 Time Elapse:0.943 max Elapse :255.062
  start : 26358723.426 ,end : 26358724.397 Time Elapse:0.971 max Elapse :255.062
  start : 26361223.360 ,end : 26361224.337 Time Elapse:0.977 max Elapse :255.062
  start : 26363723.302 ,end : 26363724.286 Time Elapse:0.984 max Elapse :255.062
  start : 26366223.146 ,end : 26366223.972 Time Elapse:0.826 max Elapse :255.062
  start : 26368723.094 ,end : 26368724.068 Time Elapse:0.975 max Elapse :255.062
  start : 26371223.060 ,end : 26371224.076 Time Elapse:1.016 max Elapse :255.062
  start : 26373722.871 ,end : 26373723.945 Time Elapse:1.075 max Elapse :255.062
  start : 26376222.788 ,end : 26376223.740 Time Elapse:0.952 max Elapse :255.062
  start : 26378722.668 ,end : 26378723.649 Time Elapse:0.981 max Elapse :255.062
  start : 26381222.630 ,end : 26381223.675 Time Elapse:1.045 max Elapse :255.062
  start : 26383722.571 ,end : 26383723.587 Time Elapse:1.016 max Elapse :255.062
  start : 26386222.379 ,end : 26386223.393 Time Elapse:1.014 max Elapse :255.062
  start : 26388722.285 ,end : 26388723.248 Time Elapse:0.963 max Elapse :255.062
  start : 26391222.260 ,end : 26391223.303 Time Elapse:1.043 max Elapse :255.062
  start : 26393722.197 ,end : 26393723.200 Time Elapse:1.003 max Elapse :255.062
  start : 26396222.039 ,end : 26396223.029 Time Elapse:0.990 max Elapse :255.062
  start : 26398721.934 ,end : 26398722.937 Time Elapse:1.003 max Elapse :255.062
  start : 26401221.897 ,end : 26401222.896 Time Elapse:0.998 max Elapse :255.062
  start : 26403721.772 ,end : 26404024.961 Time Elapse:303.189 max Elapse :303.189
106
106
2016-11-15
24 小时
 楼主| 发表于 2016-12-6 17:18:42 | 显示全部楼层
三个豹子
发表于 2016-12-8 22:23:46 | 显示全部楼层
发丢了就重新发。1ms 一次没必要,太快了
GMT+8, 2026-11-4 05:32
