查看: 6394|回复: 6
啊啊啊啊 奇怪的错误
44
44
2016-12-7
10 小时
发表于 2016-12-9 17:49:18 | 显示全部楼层 |阅读模式
2金钱
..\SOURSE\LCD12864.H(4): error C141: syntax error near 'dat', expected ')'
..\SOURSE\LCD12864.H(6): error C141: syntax error near 'com', expected ')'
..\SOURSE\LCD12864.H(7): error C141: syntax error near 'dat', expected ')'
..\SOURSE\LCD12864.H(8): error C141: syntax error near 'x', expected ')'
..\SOURSE\LCD12864.H(9): error C141: syntax error near 'x', expected ')'
H代码
#ifndef __LCD12864_H
#define __LCD12864_H
void Set_byte(u8 dat);
void Busy();
void Writer_com(u8 com);
void Writer_dat(u8 dat);
void Writer_cursor(u8 x,u8 y);
void Writer_string(u8 x,u8 y,u8 *str);
void Init_lcd12864();
#endif
C代码
#include "config.h"
#include "lcd12864.h"
        u8 i = 0;
        for(i = 0;i < 4;i++)
                e = 1;
            if(dat & 0x80)
                        rw = 1;
                        rw = 0;
                dat <<= 1;
                e = 0;
void Busy()
        u8 i = 0;
        u8 dat = 0;
        u8 dat1 = 0;
        rs = 0;
        rs = 1;
        Set_byte(0xfc);
        for(i = 0;i < 7;i++)
                if(rw & 0x01)
                        dat = 1;
                        dat = 0;
                dat |= dat;
                dat <<= 1;
        while(dat1 & 0x80);
        Busy();
        rs = 0;
           Set_byte(0xf8);//写指令
        Set_byte(com & 0xf0);
        Set_byte(com << 4);
        rs = 1;
        Busy();
        rs = 0;
        Set_byte(0xfa);
        Set_byte(dat & 0xf0);
        Set_byte(dat << 4);
        rs = 1;
        u8 cursor = 0;
        switch(x)
                case 1: cursor = 0x80;break;
                case 2: cursor = 0x90;break;
                case 3: cursor = 0x88;break;
                case 4: cursor = 0x98;break;
        cursor = y + cursor;
        Writer_com(cursor);
        Writer_cursor(x,y);
        while(*str != '\0')
                Writer_dat(*str++);
    Writer_dat(0x01);
        Delay_1ms(45);
        Writer_dat(0x30);
        Delay_1us(100);
        Writer_dat(0x30);
        Delay_1us(40);
        Writer_dat(0xC0);
        Delay_1us(100);
        Writer_dat(0x01);
        Delay_1ms(10);
        Writer_dat(0x06);
这有什么好奇怪的?很明显是你的自定义数据类型没声明好, #ifndef __LCD12864_H[/backcolor] #define __LCD12864_H[/backcolor] //在这个位子包含你的数据类型重定义头文件或者是实体 void Set_byte(u8 dat);[/backcolor] void Busy();[/backcolor] void Writer_com(u8 com);[/backcolor] void Writer_dat(u8 dat);[/backcolor] void Writer_cursor(u8 x,u8 y);[/backcolor] void Writer_string(u8 x,u8 y,u8 *str ...
54
372
984
984
2016-6-15
475 小时
发表于 2016-12-9 17:49:19 | 显示全部楼层
void Busy();
#endif
44
44
2016-12-7
10 小时
 楼主| 发表于 2016-12-14 17:07:26 | 显示全部楼层
并没有好么   我解决了  是我的lcd12864头文件里面 少了一个头文件的声明
54
372
984
984
2016-6-15
475 小时
发表于 2016-12-14 18:36:44 | 显示全部楼层
我上面说的很清楚,你的头文件中缺少数据类型定义。
59
6303
11899
11899
2014-4-1
1383 小时
发表于 2016-12-14 20:07:13 | 显示全部楼层
语法问题,怎么都好办。
44
44
2016-12-7
10 小时
 楼主| 发表于 2016-12-16 11:51:54 | 显示全部楼层
只是   少了 头文件   啊啊 但是 没有少数据声明
54
372
984
984
2016-6-15
475 小时
发表于 2016-12-16 13:59:53 | 显示全部楼层
那是因为你缺少的头文件中正好有数据声明。
GMT+8, 2026-10-23 08:48
