查看: 8822|回复: 2
STM32 SPI中的CRC效验
68
68
2012-10-15
发表于 2012-10-15 21:43:48 | 显示全部楼层 |阅读模式
 DF是这样的
      Network Layer
PEC Byte: The packet error code (PEC) byte is a cyclic
redundancy check (CRC) value calculated for all of the
bits in a register group in the order they are passed, using
the initial PEC value of 01000001 and the following
characteristic polynomial:
x8 + x2 + x + 1
To calculate the 8-bit PEC value, a simple procedure can
be established:
1. Initialize the PEC to 0100 0001.
2. For each bit DIN coming into the register group, set IN0
= DIN XOR PEC[7], then IN1 = PEC[0] XOR IN0, IN2 =
PEC[1] XOR IN0.
3. Update the 8-bit PEC as PEC[7] = PEC[6], PEC[6] =
PEC[5],……PEC[3] = PEC[2], PEC[2] = IN2, PEC[1]
= IN1, PEC[0] = IN0.
4. Go back to step 2 until all data are shifted. The 8-bit
result is the final PEC byte.
请问这个要怎么去实现 ,用STM32?
我的人生没有彩排,天天都是现场直播!
68
68
2012-10-15
 楼主| 发表于 2012-10-15 22:04:43 | 显示全部楼层
第一次发贴,发现发错地方!表示压力山大
我的人生没有彩排,天天都是现场直播!
发表于 2012-10-15 22:42:01 | 显示全部楼层
这个 没研究。
GMT+8, 2026-11-14 15:43
