查看: 3513|回复: 1
STM8S内外部时钟切换
23
52
218
218
2015-1-19
28 小时
发表于 2017-1-15 13:30:45 | 显示全部楼层 |阅读模式
   虽然STM8s的内部时钟已经经过校准,但是如果在温度变化很大的场合使用需要精准时序的应用时,就需要用温漂较小的外部时钟,先介绍一下STM8S的时钟。
   时钟源:
               STM8S的时钟源有三个,分别是:1~24MHz的外部晶振或者时钟RC时钟,上电后默认使用HSI/8最为时钟源。
   切换:
              切换手册上标注有两种,一个是自动切换,一个是手动切换,这个在一般应用中是没有差别的,自动切换就是CPU的负担小一些而已。看图吧:
           这里我们使用自动切换
实现:
         自动切换实现起来有两种,第一种就是根据手册说明来操作寄存器,第二种就是使用官方库,这两种方式我都说一下:
         官方库:
         很简单,copy我的就行 [mw_shl_code=c,true]CLK_ClockSwitchConfig(CLK_SWITCHMODE_AUTO,CLK_SOURCE_HSE,DISABLE, CLK_CURRENTCLOCKSTATE_ENABLE);[/mw_shl_code]
         原型如下:
         [mw_shl_code=c,true]/**
  * @brief  configures the Switch from one clock to another
  * @param   CLK_SwitchMode select the clock switch mode.
  * It can be set of the values of @ref CLK_SwitchMode_TypeDef
  * @param   CLK_NewClock choice of the future clock.
  * It can be set of the values of @ref CLK_Source_TypeDef
  * @param   NewState Enable or Disable the Clock Switch interrupt.
  * @param   CLK_CurrentClockState current clock to switch OFF or to keep ON.
  * It can be set of the values of @ref CLK_CurrentClockState_TypeDef
  * @note LSI selected as master clock source only if LSI_EN option bit is set.
  * @retval ErrorStatus this shows the clock switch status (ERROR/SUCCESS).
ErrorStatus CLK_ClockSwitchConfig(CLK_SwitchMode_TypeDef CLK_SwitchMode, CLK_Source_TypeDef CLK_NewClock, FunctionalState ITState, CLK_CurrentClockState_TypeDef CLK_CurrentClockState)
  CLK_Source_TypeDef clock_master;
  uint16_t DownCounter = CLK_TIMEOUT;
  ErrorStatus Swif = ERROR;
  /* Check the parameters */
  assert_param(IS_CLK_SOURCE_OK(CLK_NewClock));
  assert_param(IS_CLK_SWITCHMODE_OK(CLK_SwitchMode));
  assert_param(IS_FUNCTIONALSTATE_OK(ITState));
  assert_param(IS_CLK_CURRENTCLOCKSTATE_OK(CLK_CurrentClockState));
  /* Current clock master saving */
  clock_master = (CLK_Source_TypeDef)CLK->CMSR;
  /* Automatic switch mode management */
  if (CLK_SwitchMode == CLK_SWITCHMODE_AUTO)
    /* Enables Clock switch */
    CLK->SWCR |= CLK_SWCR_SWEN;
    /* Enables or Disables Switch interrupt */
    if (ITState != DISABLE)
      CLK->SWCR |= CLK_SWCR_SWIEN;
      CLK->SWCR &= (uint8_t)(~CLK_SWCR_SWIEN);
    /* Selection of the target clock source */
    CLK->SWR = (uint8_t)CLK_NewClock;
    /* Wait until the target clock source is ready */
    while((((CLK->SWCR & CLK_SWCR_SWBSY) != 0 )&& (DownCounter != 0)))
      DownCounter--;
    if(DownCounter != 0)
      Swif = SUCCESS;
      Swif = ERROR;
  else /* CLK_SwitchMode == CLK_SWITCHMODE_MANUAL */
    /* Enables or Disables Switch interrupt  if required  */
    while((((CLK->SWCR & CLK_SWCR_SWIF) != 0 ) && (DownCounter != 0)))
      DownCounter--;
      Swif = SUCCESS;
      Swif = ERROR;
  if(Swif != ERROR)
    /* Switch OFF current clock if required */
    if((CLK_CurrentClockState == CLK_CURRENTCLOCKSTATE_DISABLE) && ( clock_master == CLK_SOURCE_HSI))
      CLK->ICKR &= (uint8_t)(~CLK_ICKR_HSIEN);
    else if((CLK_CurrentClockState == CLK_CURRENTCLOCKSTATE_DISABLE) && ( clock_master == CLK_SOURCE_LSI))
      CLK->ICKR &= (uint8_t)(~CLK_ICKR_LSIEN);
    else if ((CLK_CurrentClockState == CLK_CURRENTCLOCKSTATE_DISABLE) && ( clock_master == CLK_SOURCE_HSE))
      CLK->ECKR &= (uint8_t)(~CLK_ECKR_HSEEN);
  return(Swif);
}[/mw_shl_code]
其次是寄存器方式,如下:
[mw_shl_code=c,true]void ChangeCLKtoHSE()
   CLK->SWCR |= 0x02;  /*允许切换时钟*/
   CLK->SWR = 0xB4;    /*选择外部时钟*/
   while(!(CLK->SWCR&0x08));
}[/mw_shl_code]
23
52
218
218
2015-1-19
28 小时
 楼主| 发表于 2017-1-15 13:32:58 | 显示全部楼层
使用官方库函数的时候,第三个参数一定要是DISABLE 就是失能中断,否则时钟不生效,有知道原因的解释一下
GMT+8, 2026-11-12 13:24
