查看: 8887|回复: 6
为什么51单片机读取DS12C887数据读不出来!
95
748
1886
1886
2012-9-16
296 小时
发表于 2012-10-28 16:47:02 | 显示全部楼层 |阅读模式
51单片机DS12C887驱动问题?为什么读出的数据是零,而且显示的字乱跳呢,代码如下,不知道是不是代码问题
2012-10-27 11:25
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
sbit rs=P3^5;
sbit lcden=P3^4;
sbit lcdrw=P3^6;
sbit rd=P3^7;
sbit dscs=P1^4;
sbit dsas=P1^5;
sbit dsrw=P1^6;
sbit dsds=P1^7;
sbit dsirq=P3^3;
//uchar count,s1num,flag,flag1;
char miao,shi,fen;
uchar code table[]="  2007-7-30 MON";
uchar code table1[]="      :  :  ";
void write_ds(uchar,uchar);
void set_alarm(uchar,uchar,uchar);
uchar read_ds(uchar);void set_time();
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void write_com(uchar com)
rs=0;
lcden=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_date(uchar date)
rs=1;
lcden=0;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void init()
uchar num;
lcden=0;
lcdrw=0;
write_ds(0x0a,0x20);
set_time();
//set_alarm(14,13,10);
write_ds(0x0B,0x26);
//read_ds(0x0c);
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
for(num=0;num<15;num++)
write_date(table[num]);
delay(5);
write_com(0x80+0x40);
for(num=0;num<12;num++)
write_date(table1[num]);
delay(5);
void write_sfm(uchar add,uchar date)
uchar shi,ge;
shi=date/10;
ge=date%10;
write_com(0x80+0x40+add);
write_date(0x30+shi);
write_date(0x30+ge);
void write_ds(uchar add,uchar date)
dscs=0;
dsas=1;
dsds=1;
dsrw=1;
P0=add;
dsas=0;
dsrw=0;
P0=date;
dsrw=1;
dsas=1;
dscs=1;
uchar read_ds(uchar add)
  uchar ds_date;
 dscs=0;
dsas=1;
dsds=1;
dsrw=1;
//    dscs=0;
P0=add;
dsas=0;
dsds=0;
P0=0xff;
ds_date=P0;
dsds=1;
dsas=1;
dscs=1;
return ds_date;
void set_time()
write_ds(4,10);
write_ds(2,32);
void set_alarm(uchar ashi,uchar afen,uchar amiao)
write_ds(1,amiao);
write_ds(3,afen);
write_ds(5,ashi);
void main()
init();
miao=read_ds(0);
fen=read_ds(2);
shi=read_ds(4);
write_sfm(10,miao);
delay(2);
write_sfm(7,fen);
delay(2);
write_sfm(4,shi);
delay(2);
启动项也设置了????[/mw_shl_code]
纵浪大化中,不喜亦不惧;应尽便须尽,无复独多虑!
发表于 2012-10-28 22:04:19 | 显示全部楼层
这东西没用过。
95
748
1886
1886
2012-9-16
296 小时
 楼主| 发表于 2012-10-28 22:20:48 | 显示全部楼层
妈的终于调出来了,原来电压要求这么苛刻!!!4.9V都不行啊!
发表于 2012-10-29 00:10:51 | 显示全部楼层
95
748
1886
1886
2012-9-16
296 小时
 楼主| 发表于 2012-11-6 12:10:40 | 显示全部楼层
用7805电压时5.03,读出来数,但是乱跳,最后就用原子的板子,出来了,现在那个项目已经结了,没做过这个,程序不难,一点小问题,耽搁了几天!3.3V和5.0V不是3.3~5.5V
29
29
2011-6-30
发表于 2012-11-22 10:53:19 | 显示全部楼层
这东西我用够了,51上用太占资,而且是假的居多,断电就不走了。
95
748
1886
1886
2012-9-16
296 小时
 楼主| 发表于 2012-11-22 18:54:34 | 显示全部楼层
回复【6楼】亚龙电子:
同意,练练手,即可!
GMT+8, 2026-11-14 08:32
