查看: 11291|回复: 10
急!!!求4.3寸电容触摸屏驱动芯片gt9147的正确参数配置
99
99
2017-3-9
17 小时
发表于 2017-3-10 11:52:26 | 显示全部楼层 |阅读模式
最近在研究正点原子的4.3寸电容触摸屏,驱动芯片是gt9147,修改了一下配置参数保存到了驱动芯片的flash中,结果发现竖屏的y轴坐标反了,即触摸屏幕左上角,得出的坐标为左下角,而且上下方有30个像素点的空白区触摸不到,估计是例程给的配置参数(那184个字节的数组)中的驱动通道没配置对,尝试调了几次也没法成功将触摸的位置与坐标对应上,希望有好心人能从工作正常的gt9147芯片中读出正确的配置参数然后发给我,也希望大家能给点解决方案,谢谢大家了。
已有好心人帮忙解决了,下面贴出正确的配置参数列表: { 0x62,0xe0,0x01,0x20,0x03,0x05,0x34,0xc0,0x01,0x08, 0x28,0x0f,0x50,0x32,0x03,0x05,0x00,0x00,0x00,0x00, 0x00,0x00,0x06,0x16,0x16,0x1f,0x14,0x89,0x28,0x0a, 0x17,0x15,0x31,0x0d,0x00,0x00,0x08,0x22,0x04,0x11, 0x00,0x00,0x00,0x00,0x00,0x03,0x82,0x08,0x08,0x00, 0x00,0x0f,0x2c,0x94,0xc5,0x02,0x07,0x00,0x00,0x04, 0x9d,0x10,0x00,0x84,0x14,0x ...
99
99
2017-3-9
17 小时
 楼主| 发表于 2017-3-10 11:52:27 | 显示全部楼层
0x9d,0x10,0x00,0x84,0x14,0x00,0x70,0x19,0x00,0x5f,
0x20,0x00,0x55,0x27,0x00,0x54,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,
0x00,0x00,0x1a,0x18,0x16,0x14,0x12,0x10,0x0e,0x0c,
0x0a,0x08,0x00,0x00,0x00,0x00,0x1f,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
0xff,0x00,0x00,0x02,0x04,0x05,0x06,0x08,0x0a,0x0c,
0x0e,0x1d,0x1e,0x1f,0x20,0x22,0x24,0x28,0x29,0xff,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf6,
再次谢谢大家的帮忙
发表于 2017-3-10 23:38:25 | 显示全部楼层
你这是手贱啊。。。回头我读一下吧。
99
99
2017-3-9
17 小时
 楼主| 发表于 2017-3-13 09:29:49 | 显示全部楼层
109
5532
10608
10608
2017-2-18
1921 小时
发表于 2017-3-14 11:51:35 | 显示全部楼层
是不是这个???
const u8 GT9147_CFG_TBL[]=
        0X60,0XE0,0X01,0X20,0X03,0X05,0X35,0X00,0X02,0X08,
        0X1E,0X08,0X50,0X3C,0X0F,0X05,0X00,0X00,0XFF,0X67,
        0X50,0X00,0X00,0X18,0X1A,0X1E,0X14,0X89,0X28,0X0A,
        0X30,0X2E,0XBB,0X0A,0X03,0X00,0X00,0X02,0X33,0X1D,
        0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X32,0X00,0X00,
        0X2A,0X1C,0X5A,0X94,0XC5,0X02,0X07,0X00,0X00,0X00,
        0XB5,0X1F,0X00,0X90,0X28,0X00,0X77,0X32,0X00,0X62,
        0X3F,0X00,0X52,0X50,0X00,0X52,0X00,0X00,0X00,0X00,
        0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
        0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X0F,
        0X0F,0X03,0X06,0X10,0X42,0XF8,0X0F,0X14,0X00,0X00,
        0X00,0X00,0X1A,0X18,0X16,0X14,0X12,0X10,0X0E,0X0C,
        0X0A,0X08,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
        0X00,0X00,0X29,0X28,0X24,0X22,0X20,0X1F,0X1E,0X1D,
        0X0E,0X0C,0X0A,0X08,0X06,0X05,0X04,0X02,0X00,0XFF,
        0X00,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
99
99
2017-3-9
17 小时
 楼主| 发表于 2017-3-14 14:17:44 | 显示全部楼层
peng1554 发表于 2017-3-14 11:51
是不是这个???
这个配置参数数组是不正确的,采用这个配置后触屏Y轴方向的坐标会调转,即触摸屏幕左上角,所得的坐标为左下角,之前能正常使用是因为触屏的配置版本号为0x62比0x60大,所以这段配置参数没有保存到gt9147的flash中,我把版本号调大将配置参数保存到gt9147的flash后就不能正常工作了。你能写段函数帮忙把这段配置参数读出来然后发给我吗?谢谢了
109
5532
10608
10608
2017-2-18
1921 小时
发表于 2017-3-14 18:14:44 | 显示全部楼层
kelaosi 发表于 2017-3-14 14:17
这个配置参数数组是不正确的,采用这个配置后触屏Y轴方向的坐标会调转,即触摸屏幕左上角,所得的坐标为 ...
楼主 ,只把0x60改成0x62,其余配置参数不变能够运行不??视频上说这些参数由生产厂商给出,而且,程序中注明低版本号是无法写入FLASH的。
99
99
2017-3-9
17 小时
 楼主| 发表于 2017-3-15 09:44:55 | 显示全部楼层
peng1554 发表于 2017-3-14 18:14
楼主 ,只把0x60改成0x62,其余配置参数不变能够运行不??视频上说这些参数由生产厂商给出,而且,程序中 ...
我就是将0x60改成了0x62将原例程配置参数数组写入到flash中才造成触摸屏异常的,原例程配置参数有地方不正确,之后我用了好心人提供的正确配置参数(2楼我发的那个,写完后我把数组中的版本号调低以防止单片机每次重启都写一次配置到gt9147的flash中)重新写入到flash中就能正常使用了
172
172
2015-11-12
28 小时
发表于 2017-8-3 09:31:02 | 显示全部楼层
你这个屏是LCD_ID为4342的RGB屏吗?分辨率是480*272还是800*480的?
334
1314
1314
2016-3-16
289 小时
发表于 2017-8-7 11:59:02 | 显示全部楼层
4.3寸电容触摸屏有两种,一种是横屏,分辨率是480*272,另外一种是竖屏,分辨率是480*800,触摸屏IC都是GT9147
70
70
2019-6-8
11 小时
发表于 昨天 18:12 | 显示全部楼层
800*480 横屏XY坐标镜像用以下CFG修复
    0x62,0x20,0x03,0xe0,0x01,0x05,0x3d,0xc0,0x01,0x08,
    0x00,0x0f,0x94,0x94,0xc5,0x02,0x07,0x00,0x00,0x04,
    0x8d,0x13,0x00,0x5c,0x1e,0x00,0x3c,0x30,0x00,0x29,
    0x4c,0x00,0x1e,0x78,0x00,0x1e,0x00,0x00,0x00,0x00,
    0x00,0x00,0x08,0x0a,0x0c,0x0e,0x10,0x12,0x14,0x16,
    0x18,0x1a,0x00,0x00,0x00,0x00,0x1f,0xff,0xff,0xff,
    0xff,0xff,0x00,0x02,0x04,0x05,0x06,0x08,0x0a,0x0c,
GMT+8, 2026-10-30 08:05
