查看: 5756|回复: 3
GSM命令语句
51
51
2016-11-22
25 小时
发表于 2017-4-19 14:51:54 | 显示全部楼层 |阅读模式
核心语句代码可以不用DMA传输么?比如下边橙色部分:
u8 sim800c_send_cmd(u8 *cmd,u8 *ack,u16 waittime)
u8 res=0;
USART2_RX_STA=0;
if((u32)cmd<=0XFF)
  while(DMA1_Channel7->CNDTR!=0); //&micro;&Egrave;&acute;&yacute;&Iacute;¨&micro;&Agrave;7&acute;&laquo;&Ecirc;&auml;&Iacute;ê&sup3;&Eacute;
  USART2->DR=(u32)cmd;
}else u2_printf("%s\r\n",cmd);//·&cent;&Euml;&Iacute;&Atilde;ü&Aacute;&icirc;
if(waittime==1100)//11s&ordm;ó&para;&Aacute;&raquo;&Oslash;&acute;&reg;&iquest;&Uacute;&Ecirc;&yacute;&frac34;&Yacute;(&Agrave;&para;&Ntilde;&Agrave;&Eacute;¨&Atilde;è&Auml;&pound;&Ecirc;&frac12;)
   Scan_Wtime = 11;  //&ETH;è&Ograve;&ordf;&para;¨&Ecirc;±&micro;&Auml;&Ecirc;±&frac14;&auml;
   TIM4_SetARR(9999);//&sup2;ú&Eacute;ú1S&para;¨&Ecirc;±&Ouml;&ETH;&para;&Iuml;
if(ack&&waittime)  //&ETH;è&Ograve;&ordf;&micro;&Egrave;&acute;&yacute;&Oacute;&brvbar;&acute;&eth;
    while(--waittime) //&micro;&Egrave;&acute;&yacute;&micro;&sup1;&frac14;&AElig;&Ecirc;±
     if(BT_Scan_mode)//&Agrave;&para;&Ntilde;&Agrave;&Eacute;¨&Atilde;è&Auml;&pound;&Ecirc;&frac12;
      res=KEY_Scan(0);//·&micro;&raquo;&Oslash;&Eacute;&Iuml;&Ograve;&raquo;&frac14;&para;
      if(res==WKUP_PRES)return 2;
     delay_ms(10);
     if(USART2_RX_STA&0X8000)//&frac12;&Oacute;&Ecirc;&Otilde;&micro;&frac12;&AElig;&Uacute;&acute;&yacute;&micro;&Auml;&Oacute;&brvbar;&acute;&eth;&frac12;á&sup1;&ucirc;
      if(sim800c_check_cmd(ack))break;//&micro;&Atilde;&micro;&frac12;&Oacute;&ETH;&ETH;§&Ecirc;&yacute;&frac34;&Yacute;
      USART2_RX_STA=0;
    if(waittime==0)res=1;
return res;
我简单的用串口3的while((USART3->SR&0X40)==0);来替代好像不成功,有大神可以解惑么,多谢!!!
u8 sim900a_send_cmd(u8 *cmd,u8 *ack,u16 waittime)
u8 res=0;
USART3_RX_STA=0;
if((u32)cmd<=0XFF)
while((USART3->SR&0X40)==0);//&micro;&Egrave;&acute;&yacute;&Eacute;&Iuml;&Ograve;&raquo;&acute;&Icirc;&Ecirc;&yacute;&frac34;&Yacute;·&cent;&Euml;&Iacute;&Iacute;ê&sup3;&Eacute;
  USART3->DR=(u32)cmd;
}else u3_printf("%s\r\n",cmd);//·&cent;&Euml;&Iacute;&Atilde;ü&Aacute;&icirc;
   delay_ms(10);
   if(USART3_RX_STA&0X8000)//&frac12;&Oacute;&Ecirc;&Otilde;&micro;&frac12;&AElig;&Uacute;&acute;&yacute;&micro;&Auml;&Oacute;&brvbar;&acute;&eth;&frac12;á&sup1;&ucirc;
    if(sim900a_check_cmd(ack))break;//&micro;&Atilde;&micro;&frac12;&Oacute;&ETH;&ETH;§&Ecirc;&yacute;&frac34;&Yacute;
    USART3_RX_STA=0;
return res;
发表于 2017-4-19 14:51:55 | 显示全部楼层
当然可以
51
51
2016-11-22
25 小时
 楼主| 发表于 2017-4-20 08:08:14 | 显示全部楼层
多谢原子哥,追问一下,是不是直接USART2->SR&0X40)==0这样就可以了?
51
51
2016-11-22
25 小时
 楼主| 发表于 2017-4-20 17:10:33 | 显示全部楼层
GMT+8, 2026-11-23 21:57
